C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] WCCH Heads... 15k mile wiggle test.
Old 01-27-2015, 12:55 AM
Gizmo5
Gizmo5's Avatar
Default WCCH Heads... 15k mile wiggle test... Hmmmmmmm
- WCCH Stage 2 Heads
- Bronze Guides
- Solid Stainless Exhaust Valves
- Dual Springs
- Heavy valve locks
- 15,000 miles
Discuss...
Gizmo5 is offline
Old 01-27-2015, 12:59 AM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
MTPZ06 is offline
Old 01-27-2015, 01:01 AM
Frankie2blue
Frankie2blue's Avatar
Those the solid SS with bronze guides? That dies NOT look promising at all. Was this car tracked or raced consistently with these heads?
Frankie2blue is offline
Old 01-27-2015, 01:36 AM
Gizmo5
Gizmo5's Avatar
Added head info to the OP
Gizmo5 is offline
Old 01-27-2015, 01:40 AM
x88
x88's Avatar
x88 is offline
Old 01-27-2015, 02:06 AM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Ever since Hib Halverson made his comments in here, and on another forum, with regard to wiggle tests, and specifically wiggle tests performed by some of these shops out there, using vise grips and other questionable techniques, I look at wiggle test results in an entirely different light.
https://www.corvetteforum.com/forums...alternate.html
'06 Quicksilver Z06 is offline
Old 01-27-2015, 02:27 AM
Mark2009
Mark2009's Avatar
Originally Posted by '06 Quicksilver Z06
[....] specifically wiggle tests performed by some of these shops out there, using vise grips and other questionable techniques [....]
Using vise grips to wiggle the valve stems?
Mark2009 is offline
Old 01-27-2015, 02:42 AM
Mark2009
Mark2009's Avatar
It would be helpful to know what brand of bronze guides are in the heads; that vendor first used one brand, then switched to another brand a year or two ago (from what I've read/heard).
Is the wiggle significantly more up and down than left-right? Even by feel?
Mark2009 is offline
Old 01-27-2015, 04:31 AM
wolf8218
wolf8218's Avatar
Whatever you say Baghdad Bob.
wolf8218 is offline
Old 01-27-2015, 05:07 AM
BoostedEBZ06
BoostedEBZ06's Avatar
Getting my popcorn ready.....
BoostedEBZ06 is offline
Old 01-27-2015, 06:54 AM
Uncle Meat
Uncle Meat's Avatar
Uncle Meat is offline
Old 01-27-2015, 07:23 AM
SuperchargedTundra
SuperchargedTundra's Avatar
SuperchargedTundra is offline
Old 01-27-2015, 07:47 AM
Jasonoff
Jasonoff's Avatar
In before more excuses start flying around.
Jasonoff is offline
Old 01-27-2015, 07:55 AM
ctsv510
ctsv510's Avatar
Who's car is this and when were the heads rebuilt?
Is this the car that AH was referring to back in July?
Originally Posted by American Heritage
The vehicle had headers only, no cam. The vehicle was brought into the shop by the new owner as a post purchase inspection. He was told when he purchased the car that the heads were rebuilt around 20,000 miles ago. I have no idea how the previous owner drove the vehicle (road, track, canyon runs, daily driving, ect...) or even if they were truly rebuilt 20,000 miles ago (sometimes when selling a car the seller doesn't tell the complete truth). We just did a wiggle test before removing and reworking the heads. Heads had bronze guides dual springs and SS exh valves. Most of the exhausts were right on the border of spec but two were substantially out of spec on the wiggle test (.0095" was the worst of the wiggle test results). Off the top of my head if I remember correctly it was the #5 and #6 exh valves that were the most out of spec.
I will try to find the full wiggle test result sheet for this customer and post it. The vehicle was in our shop 4 months ago.
ctsv510 is offline
Old 01-27-2015, 08:09 AM
wjnjr
wjnjr's Avatar
wjnjr is offline
Old 01-27-2015, 08:32 AM
ConfusedGarage
ConfusedGarage's Avatar
Were these just tumble polished intake valves or did they actually use the proper coated valves from Katech to mesh with the bronze guides?
ConfusedGarage is offline
Old 01-27-2015, 08:33 AM
vertC6
vertC6's Avatar
Did it have a cam and if so what size?
vertC6 is offline
To WCCH Heads... 15k mile wiggle test.
Old 01-27-2015, 08:56 AM
Michael_D
Michael_D's Avatar
- Bronze Guides
- Dual Springs
- Heavy valve locks
- 15,000 miles
Discuss...
The head are off, why are you f'ing around with a 'wiggle' test? Get a mic and bore bore gauge.
Did you check rocker wipe/scrub when you installed the heads? Did you check seat runout and stem clearance and spring height when you installed them.
Or more importantly, did you do the work, buy the car from someone else?? What's the back story here?
Michael_D is offline
Old 01-27-2015, 09:01 AM
RFZ
RFZ's Avatar
personally i would never use bronze guides on my street car. my experience is they wear fast. love all the banter on this forum about valves/guides. looks like the repair on those heads didn't work out so well. still have stock setup on my 49k mile 07. still running strong. looking forward to the discussion why they are worn.
RFZ is offline
Old 01-27-2015, 09:28 AM
'06 Quicksilver Z06
Reading Hib's article he makes interesting points.
Hib brought up several interesting points and his article made me wonder just how many cylinder head repair jobs have been sold to owners out there, based on wiggle tests using techniques which may or may not yield accurate results.
Halverson's article points out and explains very well, why some of the testing methods in use today when performing what is commonly referred to as "the wiggle test", present accuracy problems.
As such, any time I see video and or results of wiggle tests, I think back to some of what he writes in the article.
But one has already asked a very important question here: Why do a wiggle test if the head is already off as opposed to direct measurements?
Of course though, any video using a measuring technique which has recently come into question and attempting to show a competitor's offering in negative light, well that's going to work on some, but not others.
Of course after pointing this out now, I wouldn't be surprised if a listing of numbers indicating actual measurements were to appear.
As an aside, I suppose it's time for Katech and their customers to start getting concerned about that video, as WCCH has done much of their cylinder head machine work for them and using bronze intake and exgaust valve guides.
Quick Reply: [Z06] WCCH Heads... 15k mile wiggle test.
