[Z06] Katech Stage 2 Z06 SN#78
Premium Supporting Vendor
I particularly like the was anodize red powdercoat matches crystal red tintcoat on this one. The powdercoat is a base silver with red tintcoat.
K501 cam
CNC ported heads
Bronze guides
Ti/Mo intake/exhaust valves
FAST intake
Billet fuel rails
Katech valve covers
Anodize red powdercoating
Katech billet belt tensioner
Corsa mufflers
Halltech Systems, LLC CF112 intake
13000 miles
K501 cam
CNC ported heads
Bronze guides
FAST intake
Billet fuel rails
Katech valve covers
Corsa mufflers
13000 miles
Hot427Z06 Coming Home
Looks great!! No more valve worries. Time to drive it like I stole it again!! I was wondering how close the Anodized Red valve cover would match the Crystal Red.
Jason please verify they installed the ATI Damper and High speed lifters.
See you Thursday.
See you Thursday.
Yes on the ATI damper and lifters. These posts are just the Cliff's Notes.
Sweet
C2 of Year Finalist (performance mods) 2019
Jason, you have had close to 80 cars where the heads were sent to WCCH. Could you share with the forum how many were out of spec on the value guides. Also, have you had an opportunity to measure any of your early builds for guide wear. Thanks
OP,beautiful car. Now you can really enjoy it. How many miles are on it?
The serial number sequence is for all C6 Z06 packages so some of those were stage 1s without head work. Many of them were early on before anything was known about guides. We have had some early ones come back with worn guides, but it can be hit or miss. For example Jim Painter's car came back this year for a rebuild, which has seen a lot of hard track use. I expected to see completely blown out guides. They were out of spec but not as bad as I was expecting. In the last year or so we have been saving every measurement sheet in the work order folder, but have not took the time to put together any kind of matrix. However it seems like every car that we look at now has worn out guides to some degree.
Sn #78
Heads were not milled because they were still flat. I like the idea of the thicker aluminium heads when at 640-650 Hp.
Jason said that a .030 milling only gains you 5 Hp but now that I see Stage 2 #80s dyno sheet I wonder? Stage 2 #80's build is identical except he has the carbon fiber heat shield and the .030 head milling.
