C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Brake fluid capacity
Old 05-02-2016, 09:59 AM
herfc00
herfc00's Avatar
Default Brake fluid capacity
Does anyone know the brake fluid capacity fo a 2012 Z06 with carbon ceramic brakes? Thanks,
Randy
Old 05-03-2016, 08:58 AM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Well....whadayu need to know for??
If you're gonna remove the calipers, drain the complete system including the ABS circuits, flush the system to clean it, and then refill, you'll probably need close to 2 liters.
However, if you're just doing something like flushing in some DOT 4 fluid for the track, 1 liter should do.
Old 05-03-2016, 09:46 AM
herfc00
herfc00's Avatar
Thank you!
To Brake fluid capacity
Quick Reply: [Z06] Brake fluid capacity
