C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] AC Delco UltraGuard UPF48R Oil Filters Available
Old 12-25-2008, 02:32 AM
titleist731
titleist731's Avatar
do these fit for older z06's or only 2009?
titleist731 is offline
Old 12-27-2008, 05:15 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
All Z06's take the PF48, so yes, you can use the UPF48R. This is all year Z06's (C6).
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Gene Culley is offline
Old 12-27-2008, 05:55 PM
black08ls3
black08ls3's Avatar
Default Question for Gene Culley: UPF48R Oil Filter
Gene Culley,
I have a 2008 LS3 and would like to use this upgraded UPF48R oil filter in place of the standard PF48 oil filter. It is my understanding that the
UPF48R is a direct replacement for any vehicle that uses a PF48 as standard equipment. I trust that the thread size and diameter is exactly the same as the PF48 (please verify). Also, I believe that the PF48 filter has a bypasss valve inside the filter instead of integrated in the vehicle. Do these UPF48R oil filters have this bypass valve as well? It is quite visible if you look inside the oil filter. I want to be careful when I deviate from the specified oil filter. I am sure that you understand.
black08ls3 is offline
Old 01-01-2009, 11:46 AM
Gene Culley
Originally Posted by black08ls3
Gene Culley,
I can certainly understand your concern. Yes, the UPF48 is a direct replacement and has all of the features of the stock PF48, but with better filtration, etc.
Quick Reply: [ZR1] AC Delco UltraGuard UPF48R Oil Filters Available
