Top Flight Reproductions C6 Front License Plate Bracket
How does that bracket hold up to triple digit blasts (upwards of 200mph) and how does it affect drag? It really looks nice, but it sure is a big drag creator on the front of the car.
There is a strip of foam on the back side of the bracket and when the bracket is installed there is a approx a 3/8 gap between the foam and the face of the lower bumper, no contact
In Stock!
The Top Flight Reproductions C6 front license plate bracket is the best looking mount available. It follows the contour of the front bumper. Installs easily without lifting the car. Requires no drilling for attachment like some others do. Our bracket is priced considerably lower than other after market solutions and is made in the USA
All three Top Flight Reproductions front license plate brackets are in stock and ready to ship. Visit our website at www.topflightrepro.com or call 781-279-1279 and ask for Ray.
C6 GS/Z06/ZR1 Removable Front License Plate Mounting Bracket
#33
I could bend the bracket. Right now I have a 60 day Temp Tag so I an not worried, I am sure it will work out. I have a friend with a 2012 ZR-1 and I will see what he has done.
#35
#36
A little history:
I used your removable bracket on my Grand Sport and it worked great.
When I got my 2012 ZR1 I tried the same bracket, but it doesn't fit too well. The problem is that the bottom part of the bumper sticks out about an inch further than the top, resulting in what I consider an ugly gap at the top.
So here is what I did to alleviate the problem:
1 I happen to own a machine shop, so I milled 2 slots where the mounting holes were so all I have to do is loosen the wing nuts to remove or replace the plate.
2 I bent the bracket about 5 deg off 90 to better fit the ZR1 shape, being careful not to break the spot welds.
Now I am a happy camper the bracket looks and works great.
#38
A little history:
#39
In Stock!
#40
I used mine without the frame, works great, no change in coolant temp, no damage to paint. I'm gonna need a new one as I just traded my ZO6 for a ZR1, need a new vanity plate also.
