[ZR1] ZR1 top speed in each gear
You can calculate the speeds by using the following.....
66 mph in 1st gear. The gear ratios are as follows:
First Gear Ratio (:1) 2.29 66mph
Second Gear Ratio (:1) 1.61
Third Gear Ratio (:1) 1.21
Fourth Gear Ratio (:1) 1.00
Fifth Gear Ratio (:1) 0.81
Sixth Gear Ratio (:1) 0.67
Reverse Ratio (:1) 3.11
Clutch Size N/A in
Final Drive Axle Ratio (:1) 3.42
Clutch Size N/A in
My Calculations brought me to
1st: 64.3 mph
2nd: 91.5 mph
3rd: 121.8 mph
4th: 147.3 mph
5th: 181.9 mph
6th: 219.9 mph
Used this calculator
http://www.car-videos.net/tools/spee...B1=Recalculate
1st: 64.3 mph
2nd: 91.5 mph
3rd: 121.8 mph
4th: 147.3 mph
5th: 181.9 mph
6th: 219.9 mph
64 mph 1st.
95 mph 2nd.
127 mph 3rd.
151 mph 4th (this is pretty solid as i hit this on one of the straights at buttonwillow and didn't bother to upshift for the last bit of straight)
i have to guess 175 for 5th. on this run i short shifted a little around 170... but was fairly close to redline... again, paying even less attention to the guages and more to driving.
Here ya go - just click on the ZR1 link in this great calculator put up by forum member leres:
http://xse.com/leres/z06/calculator.html
Bob
Bob
