[ZR1] Launch Control - Burning Smell
I used my launch control for the first time. Wow, the car is fast. But the more major concern is the car smelled like something was burning thereafter. It was a sweet burning smell. Anyone else experience this?
Scott
Scott
Press the traction control button until it reads competitive mode on the DIC.
Then point it straight. Push in the clutch in - put it in first - Floor the gas pedal( it should rev to 4000-4500 rpm and it will stay at that rpm with the gas pedal floored) -- Then Dump the clutch fast and hang on.
here is youtube video of a corvette engineer describing how it works.
http://www.youtube.com/watch?v=rpDievbsgzU
its a feature with in the competitive driving mode.
Its a cool feature designed as a one up to the Nissan gtR which had it in 2009. GM;s claim to fame with their launch control was if you use it you do not void the warranty. On the Nssan GTR if you used launch control it tracked it in the computer and your warranty was voided the next time you take it in for service and the mechanic scans the ecm.
For 2010 Nissan did away with the launch control feature in the GTR.
i do not think i would make a habit of using it.
I think these zr1 and z06 corvettes have a lot going for them with just rolling into the Gas.
I am thinking it was the clutch, because I can't remember how fast I dumped it. Oh well, it was fun and it is warrantied.
That whole thing about the GTRs not being able to use launch control without losing their warranties is just wrong.
Scott
Scott
Scott
in the case of the GTR it wasn't the clutch in question, since it is essentially an automatic. Owners were blowing their entire tranny and Nissan voided the warranty, that was the major issue.
In the case of the vettes, the tranny is covered, clutch is case by case. since you can burn out a clutch on a none- launch control car, just by riding it. Clutch is a normal wear and tear item like tires and brake.
