[ZR1] Tire shake 70/80
Tire shake 70/80
Just wanted to let everyone know I had the tire shake, heard it would go away and it did. She is at 2900 miles and no shake at all. I didn't do a thing except burnish the brakes and enjoy the driving pleasure. What a machine!!! I recieved the book this week. I am a first time Corvette owner.
OK, what is causing this shake. Tires flat spotted perhaps? I am curious and a bit concerned because I am close to pulling the trigger on a cyber gray '10.
Thanks.
Thanks.
Some have it, some don't. It seems to get better over time for many that have it.
Take a look at this thread and you'll know what the forum has found out:
http://forums.corvetteforum.com/c6-c...l-balance.html
Bob
Don't bother asking your local dealer as you'll likely get bad info.I'm sitting tight waiting for one of the many forum members to figure it out.I"m getting a little annoyed about this--2010.1100miles.
Well....nobody is quite sure!!
Bob
Bob
Frankly, this is giving me a lot of concern...
I have a 09 Z06 with the Factory chrome spyders. I recently put a set of 3 piece 20/20 wheels and tires on it. Before putting the new wheels and tires on I had zero shake at the 70-75 mph treshold. I put the aftermarket set on and it was perfect as well. I had a small problem with one of the aftermarket wheels so I had to send the one wheel back to manufacturer for repair. While the one wheel was out for repair I put the factory spyders back on. The car will shake your teeth out at 75 mph now. Same wheels and tires put back on the same corners they originally came from. I think someone said on here it was a wheel indexing problem and the way to fix it was to keep removing wheels and changing position on lugs one space at a time. What a pia that would be. I got my 3 piece wheel back and reinstalled them. Now they are perfect again.
How did you store your original wheels/tires when they were off the car? Did you lay them down or were they standing up?
What air pressure did you have in them while in storage, once reinstalled?
Stored them laying down on a wood pallet. 30 pounds both times. They where only off car for a month before I needed to reinstall them. I think they vibrated on the reinstall because they where not in the same exact position on lugs as they where when they left the factory.
