C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] ZR1 front suspension
Old 02-27-2011, 02:02 PM
wstaab
wstaab's Avatar
Default ZR1 front suspension
Anyone have pictures of ZR1 lower front suspension control arms they can post or email?
Old 02-27-2011, 07:46 PM
dvandentop
dvandentop's Avatar
http://corvetteactioncenter.com/gall...splay/cat/6086
were you thinking there were some differences?
Old 02-28-2011, 11:41 AM
wstaab
wstaab's Avatar
I need pictures from an actual car with all the appendages that are attached to the front lower controls arm. I need to compare something on the new Z06 Carbon front suspension.
Thanks.
Old 02-28-2011, 06:07 PM
dvandentop
dvandentop's Avatar
what do you think has changed?
Old 02-28-2011, 07:42 PM
wstaab
wstaab's Avatar
Aero appendages.
Old 02-28-2011, 09:30 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Here ya go, Bill - I hope these will show what you're looking for!!
I didn't jack the car - I just sat the camera on the garage floor in front of the splitter looking back at the area I think you're interested in. The picture above is looking back at the left front wheel. With the splitter, they seem to have left a gap in the spoiler/air dam thingies that hang down, and then there's another piece that is bolted to the front of the lower A-arm.
The picture above is a closer look at the piece on the control arm.
I imagine that the Carbon Edition with a splitter is exactly the same as the ZR1.
Do those pictures show what you wanted to see? If not, let me know if I can take some more.
Bob
Old 02-28-2011, 09:35 PM
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Steve Snake Driver's Avatar
Is that an aerodynamic aid or just a bit of protection for the carbon-ceramic disks?
Old 02-28-2011, 09:38 PM
dvandentop
dvandentop's Avatar
interesting woulda never noticed them
Old 02-28-2011, 09:49 PM
BEZ06
BEZ06's Avatar
I don't think it's to "protect" the rotor.
The way it's attached to the A-arm, it angles back and would actually maybe deflect stones and junk over onto the rotor. For that reason, it looks like in addition to aero effects it might have, it also might help feed cooling air over onto the rotor.
So.....I think it's aero and maybe brake cooling, but I'm looking forward to other folks' input!!!
Bob
Old 02-28-2011, 09:56 PM
Steve Snake Driver
So.....I think it's aero and maybe brake cooling, but I'm looking forward to other folks input!!!
Bob
Brake cooling popped into my mind, but after seeing what the brake burnishing procedure requires, I'd be doubtful about that being the reason.
Old 02-28-2011, 10:28 PM
wstaab
wstaab's Avatar
Bob
Thanks Bob.
That is the picture I needed.
It is designed to direct more air to the brake rotor at speed.
What year is your ZR1?
Old 02-28-2011, 11:15 PM
range96
range96's Avatar
Received 1,974 Likes on 1,215 Posts
My 2010 looks exactly like that. First time I saw it wasn't sure if it suppose to channel air out from underneath the car or for cooling brakes. My service guy thought it was for additional brake cooling. Maybe it is to preserve the tie rods, ball joints and bearings from excessive heat.
I think a car that goes 205mph NEEDS this kind of additions.
Old 02-28-2011, 11:25 PM
BEZ06
BEZ06's Avatar
Mine is a 2009. It was built in Aug '09 and is #1337, so it's pretty close to the end of the '09 run.
Bob
Old 03-01-2011, 07:43 PM
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
They are for directing air to the rotors. GM lists the parts as "front brake cooling air deflectors" in the parts catalog. They are listed the same for ZR1 as well as Z06 optioned cars.
Old 03-02-2011, 12:36 PM
wstaab
wstaab's Avatar
Do you show a different part number for a 2011 Z06 Carbon Edition?
Old 03-02-2011, 02:47 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
It's the same for ZR1 and the CE Z07
Old 03-02-2011, 06:49 PM
wstaab
wstaab's Avatar
To ZR1 front suspension
Old 03-08-2011, 04:56 PM
Rob Willis
Rob Willis's Avatar
How much? Part #?
Old 03-09-2011, 04:44 PM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
Originally Posted by Rob Willis
How much? Part #?
$55 each side. 20772014 / 20772013
Old 03-10-2011, 07:05 PM
Rob Willis
Rob Willis's Avatar
No hole provisions on the arms on cars other then ZR1 I presume. Not on my GS.
Quick Reply: [ZR1] ZR1 front suspension
