[ZR1] Cure for the Common Curb...
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Introducing the "Cure for the Common Curb". Front end damage when parking is a very real problem for many cars on the road today, especially for vehicles who have installed ground effects or aerodynamic profile improvements on their vehicles. Curbs are something that are one of those road hazards that do more damage to sports cars than any other hazard on the road.
In fact, just a simple trip to the corner store can become a costly errand if you over-estimate your front end clearance when parking: damage repairs could easily run $1000 or more; however, Curb Alert provides you a warning system that gives you three-deep warning tones as you approach too close to a curb.
The Curb Alert is very easy to install and does not put a drain on your battery when the car is not on. Using a patented infrared technology, the front mounted sensor is calibrated to a warning distance of anywhere from 8-28" (you decide with whatever you feel comfortable with). The warning alarm is hidden in the car and will give you three gentle tones when you are within a specified distance to the curb. The system gives you a short beep every time you start your car to let you know the system is active.
The Curb Alert is one of a kind and is a gadget that will save you money in the long run, preventing front end damage to any car that is low enough to be vulnerable to a Curb. Do not take a chance, get the Curb Alert to prevent curb damage.
This is not one of those gimmicky products, we have installed it on a Corvette C6 Z06, Nissan GTR, and a Dodge Challenger. In all instances it works exactly as described (we wanted to test it ourselves before we opened the flood gates ) It is the real deal and will save you money in the long run. Heck it might it even give you enough confidence to let your significant other take the car for spin (my biggest worry letting someone else drive my car is there lack of familiarity with judging the curb distance when parking)
Installation Instructions (we are the only ones offering Custom Install packages and videos to install on the C5, C6 and Camaro) and videos are at the link below
We have the Curb Alert in stock for 149.99 with free shipping.... at the link below...Also have a great video that shows how the system works and another video on how to calibrate it once installed.
Mini Curb Alert
Thanks,
Jim
Mini Curb Alert
Thanks,
Jim
__________________
pm me for price....I will be at Millers Ale House this Sat. 12/10
for Toys for Tots 11am - 4pm
I am not overly excited about cutting the weather strip or removing it to get the wire in the passenger compartment. Do you have a video or written instructions on how to get the wire through the firewall including where on the firewall it would be penetrated?
Doug
Doug
Supporting Vendor
Hi Doug,
You do not have to cut or remove the weather stripping at all....Watch the video, it tucks right in between the quarter panel and the door. Not cutting at all (trust me, I would not want to do that either, nor would I).
The only thing you need to do for a clean install and no wire showing is pop off the plastic trim piece (it is about 6" long and 2" wide) right along the inside of the vertical part of the door jam. It has two pop in clips on the back of it. Snaps in and out very easily.
Trust me, you do NOT want to try and bring the wire through the firewall. If you think popping that plastic piece of the interior is tricky, getting through the firewall will be like nails on a blackboard for you .
I would not even think about it, unless I was paying a stereo shop to do the install.
Take a look at the video again, the install is VERY EASY and you do not have to cut, drill, or modify ANYTHING in your car at all...
If you have questions at all, feel free to call me on my cell anytime.
Shoot me a PM and I will send it too you if needed.
Thanks,
Jim
Thanks,
Jim
Supporting Vendor
Would of loved to see you car....
Price is at the link below, also have an installation video for the ZR1...
One of the biggest fears with purchasing the Curb Alert is the installation, folks are unsure how "difficult" the installation is.
To make it easy for Corvette drivers, we just created a Corvette specific Curb Alert install package for the C6 that allows you to do the whole installation within 1 hour. Checkout the video on the page below and you can see the entire installation on a 2009 C6.
Corvette Curb Alert
This is a Southern Car Parts exclusive Corvette Curb Alert package for that has everything crimped and ready to go. Run the wires and plug it in to the fuse box under the passenger floor board and you are off and running.
Just select the Corvette Specific Package when checking out and we will "pre-stage" everything for you prior to shipping so you can install it exactly like in the video.
Video is down towards the bottom of the page....
Corvette Curb Alert Install Video
Thanks,
Jim
Curb Alert
Mini Curb Alert
Thanks,
David
Mini Curb Alert
Thanks,
David
Received mine today. Great seller with great service and fast shipping. Second purchase from them.
I installed it per the instructions but having a little trouble calibrating. Works but needs to be tweaked a bit. I'm sure it will be fine when I can spend a little more time with it. Straightforward installation otherwise and video on website helped.
Supporting Vendor
Curb Alert
I have been using the Curb Alert for four years and it has never failed me. When routing the wire from the engine compartment to the passenger compartment I have an exposed wire of about 2-3 inches where the door closes. No interference and absolutely no problem. I did have to use heavy duty double stick tape when mounting the warning alarm. Got it at Home Depot.
Supporting Vendor
Supporting Vendor
Mini Curb Alert
Thanks,
David
Mini Curb Alert
Thanks,
David
