[ZR1] ZR1 Vibration Issues
#581
so how does one go about getting the rotors AND wheel balanced together??? is this done on a road force machine also? or just a normal balancing machine? assuming i may be dealing with idiots what do i tell them to do when i say "i need to get my rotors balanced along with the wheels..."? my vibration/shake is so bad i can see it in the body of the car while cruising... wonder if people cruising along side of me can see the entire car shaking??
7.0Ltrs of Love (07-08-2016)
#582
#584
I noticed my rotors do have those little bolt on weights like pictured earlier in this thread but obviously either not good enough or something has changed.. So elaborate on how I get these rotors "fixed" dealer ship and get them rebalanced or will they give me new replacements ? Car is a 2012 with 12k on it so should still be warrantied technically. ..
#585
So it seems I also have the vibration issue on my 2011 zr1. At first I assumed it was because the car had the original (read old) tires when I bought it but I just replaced the wheels and tires, had them road force balanced and I still have vibrations at 80mph.
Question I have is, has anyone ran the car up to high speeds (150+mph) with the vibration issue? Was it safe?
I have a local 1/2 mile event coming up and I'm not sure I'll have time to go through all the bs procedures before the event to try and fix the issue but I want to be safe as well
#586
And has anyone tried to "balance" the assembly by using 1 or more heavier lug nuts?
If the rotor is unbalanced by 1oz maybe it would balance out by having a 1.5oz heavier lug nut near the unbalance location, no?
#587
i dont think that would work as the lug nuts are near (on top of) the hat. The unbalanced location is on the edge of the rotor. That is close to where you place the temp wheel weight (on the wheel).
#588
Any answers to my first questions?
#589
Well I ended up bitting the bullet and having the rotors and wheels balanced. Not to difficult aside from taking it all apart and back together. But I'm glad I did as the car is not nice a smooth.
1 front rotor was out by 1oz and one rear was out by .25oz, other 2 were good.
#590
Well I ended up hitting the bullet and having the rotors and wheels balanced. Not to difficult aside from taking it all apart and back together. But I'm glad I did as the car is not nice a smooth.
#591
#596
I got mine done at a local shop, The manager let me come in on a Saturday and he and I did them. Keep looking, try a speed shop where they might let you participate.
#597
neither occurs. The rotors are spun separately to determine the imbalance. Once you know this you can balance the wheel and then put the wheel out of balance with the corresponding weight of the rotor imbalance. PM me with your email and i can send you the aston martin procedure.
#598
#599
Dealing with the same issue. Have had the car balanced several times now, including road force balancing. Found this thread this morning and must have called 5-6 dealerships. All spoke to me like I was an idiot. Every single one told me that rotors can't be balanced. Called Coughlin Chevrolet last and spoke with the Vette tech. He had one customer with this issue, they put the rotors on the balancer and ended up replacing. Sounds like we're on our own.
#600
