[ZR1] Road & Track - ZR1 vs. C6.R
#62
Former Vendor
I not so sure that the C6R will out accerlate the ZR1. The current GT2 car has 470 horsepower which at 2700 pounds it puts the pounds per horspower at around 5.74. The ZR1 at 3300 pounds comes in at around 5.17 pounds per horspower. This is calculated without the driver so I know that will come into play. Also, I understand that the C6r can change the gearing to make acceleration optimal and of course have race tires but I think if you put drag radials on the ZR1 and put it on good prep drag strip with somebody like Kyle Lemish driving the ZR1 may come out on top. It doesn't really matter but would be cool to see.
#63
According to corvetteracing.com the GT2 C6.R uses a 6.0 liter engine making 470 horsepower at 4800 rpm and 535 ib/ ft of torque at4500 rpm. I am not an expert on the C6.R but this coming from their website. I would not think they could fudge the numbers either since it is a sanctioned racing series. Maybe the info they have posted is wrong.
#64
Originally Posted by MARK'S C5TT
On a roadcourse, turns and braking rule
I'm quite familiar with Sebring. Think of it as having 10 straights over its 3.7 miles. It's not a tight course, but it's bumpy. And remember, a straight can be a very short section of track between two turns or even bends, which themselves can often be 'straightened' out depending on line.
#65
Received 2,051 Likes
#66
They use a 5.5L engine now and it's supposedly restricted to 500bhp as stated in the article. Not sure how long that drag race was or the gearing in the C6R trans at the time, but the fact that it is much lighter helps it accelerate much quicker off the line and it's shift speeds are twice as fast as humanly possible by even Kyle. With that being said the article did mention that the ZR1 made up a 10mph deficit on the long straight(Section E in the datalog) closing a 15mph deficit to just 5 mph difference from corner to corner, so that indicates to me a roll race would favor a ZR1 over a C6R.
#67
According to the article, the ZR1 had the PDE option, it was 95lb heavier than the Z06 and it was slower than the Z06 with Z07.
Why? 133hp isn't enough to overcome the 95lb deficit? Spring Mountain isn't that tight of a course.
Not looking for a "fight" here, just curious, really.
z51vett
#68
Zr1s are fast cars but not so light. My old 02 z which is heavily modded for track use easily spanks new z06s and zr1s on track days. It is lighter, has more hp, and very sticky slicks. Large radiator and oil coolers allow it to run cool so as to not loose hp. It is fun to **** off guys who think they have the fastest around 'cause some magazine says so. I want a zr1 anyway because it is such a civilized car for as fast as it is.
#69
The "so called current Le Mans driver" as you put it is Tommy Milner, the "so called" last winner of Le Mans in a Corvette. So contrary to what you might believe (or seem to be insinuating) he can wheel a car. I was just at Spring Mountain 2 weeks ago and believe it or not if you take the time to speak to the instructors most of them indicate that they also prefer the Z06's over the ZR1 on the track. The reason being is that it is lighter, slightly more nimble and easier to drive (because it is not overpowered). The results are the results and as they say when the clock comes out the BS walks. So setting your ego aside (and your $20k) it is slower around that track. If you want to run a wide open road race then the added HP of the ZR1 will probably put it in the front, on that track on that day it did not.
The moment they decided to release the Z06 with the ZR1 brakes and cf, the ZR1 was headed to a tough match. Light weight beats HP on most tracks.
However, in the real world, the driver will make the difference in who wins between these two cars. PERIOD. You put a good driver in one and an avg driver in the other and the good driver will win, whichever car he/she is driving.
That all said, I wouldn't trade my ZR1 for a Z06. Well, maybe a maxed out 2012 Z06....
