[ZR1] Katech Stage 4 ZR1 SN#06
Premium Supporting Vendor
Stage 4
800HP / 700 FT-LBS*
LS9 overdrive damper
Katech ZR1 high capacity heat exchanger
Lingenfelter 2.60″ supercharger pulley
Lingenfelter supercharger snout
Lingenfelter GT9 camshaft
CNC-ported heads
Bronze valve guides
Katech Ti/Mo intake valves
ARP head studs
LS9 head gaskets
PSI valve springs
Trend pushrods
Katech C5-R timing chain
Denso IT22 spark plugs
Chassis dyno calibration
Serialized plaque
+Corsa exhaust
800HP / 700 FT-LBS*
CNC-ported heads
Bronze valve guides
ARP head studs
LS9 head gaskets
PSI valve springs
Trend pushrods
Serialized plaque
+Corsa exhaust
The Consigliere
Received 5,431 Likes
Cool set up.
