C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] 2012 Cat Questions?
Old 05-23-2013, 08:19 AM
Chase99
Chase99's Avatar
Default 2012 Cat Questions?
Own a 2012 zr1 with the second set of cats and I have installed a B&B Fusion cat back exhaust and have the following questions....
- Can I remove the second set of cats and put on an x-pipe without the car throwing a code
- will removing them lean the car out enough to need a tune
- if removed the cats are will the car pass my state emissions test
Thanks for all answers
Old 05-23-2013, 10:27 AM
OBSSSD
OBSSSD's Avatar
yes
no
yes
Cheers!
Old 05-23-2013, 12:51 PM
911/Q45
Support Corvetteforum!
911/Q45's Avatar
Depends on your state and how knowledgable your inspector is. In CA any removal of emissions equipment will fail you.
Old 05-23-2013, 12:55 PM
Chase99
Chase99's Avatar
What manufacture makes an x pipe replacement for the 2012 and up models? i aasume the length and/or the flanges could be an issue?
Old 05-23-2013, 02:02 PM
OBSSSD
OBSSSD's Avatar
You need a 2009-11 set of ZR1 cats with center section to install with your existing stock manifolds. Call John at 21st Century Musclecars at 972-417-7177 and I bet he has a set he could make you a deal on.
You will not have any emissions issues just be like the older year cars which pass just fine.
Old 05-23-2013, 02:07 PM
BenDiem
BenDiem's Avatar
^^^ OP,
If you don't mind me asking, I'm curious, did you have any fitment issues with installing the catback? I'm considering an aftermarket catback myself.
Are you not happy with the sound of the catback, and is that why you are looking to add an x-pipe?
BTW, I could have sworn, the '12 & '13 Z06/ZR1s have an x-pipe...
Tks/Cheers,
B
Old 05-23-2013, 02:22 PM
OBSSSD
OBSSSD's Avatar
They do, but with a second set of cats in the center section
Old 05-23-2013, 02:27 PM
ZR1Cat
ZR1Cat's Avatar
If this is correct, then why did GM add this second set of cats on the 2012-13s? Did the change in 2012 just affect the ZR1s or also the ZO6s, etc?
Old 05-23-2013, 03:45 PM
OBSSSD
OBSSSD's Avatar
All the cars got extra cats...
base car, GS, Z06, and ZR1
If it was actually an issue then what are people with 2009-11 ZR1's doing now to pass? There has never been a single poster that said they failed emissions visual or otherwise with the old setup on here - because it has never happened. Do you really think an inspection station would know this distinction?
There will be no issues but if you are that scared better not to modify your car at all
Old 05-23-2013, 03:57 PM
911/Q45
911/Q45's Avatar
That may be true in TX, but they would know in CA. What state is the OP from?
Old 05-23-2013, 04:27 PM
ZR1Cat
ZR1Cat's Avatar
You may not have understood my post. I am not planning to modify my exhaust. I am just wondering why GM added an extra set of cats to a system (2009-11) that apparently was working well to being with. Why add the extra cost of the cats to a supposedly well designed existing system? What was GM trying to accomplish with the additional cats?
Old 05-23-2013, 05:26 PM
OBSSSD
OBSSSD's Avatar
So then what are all the people with 2009-2011 ZR1's that live in California doing? Guess letting their cats rot in the garage
Old 05-23-2013, 06:55 PM
mirage2991
mirage2991's Avatar
my guess is that emissions were scheduled to go up in 2012, and perhaps that was the only way to "improve" the system
Old 05-23-2013, 06:56 PM
911/Q45
911/Q45's Avatar
Those of us with 2009-2011 ZR1s comply with our stock setup as installed, if you have a 2012 and remove the added cats you don't comply and would fail the inspection and be denied license renewal. I don't understand what you are saying.
Old 05-23-2013, 11:06 PM
OBSSSD
OBSSSD's Avatar
There are thousands of C6 owners who have headers with hi-flow cats in California that pass inspection every year - yet you think some dufus at an inspection station is going to know the difference between the 2011 and 2012 factory exhaust setup?
LMAO
Old 11-16-2014, 11:50 PM
Streetk14
Streetk14's Avatar
Sorry for resurrecting an old thread, but it was left open-ended with some pretty bad information.
1) Government emissions standards changed right around the 2012 model year. GM added additional catalytic converters in the X-pipes of ALL C6 models for this reason.
2) a 2012 or 2013 car isn't going to need a smog check for at least 6 years. Really not something to worry about.
3) No smog station tech is going to notice that the car doesn't have the rear cats. Unless you're a C6 guru, it's not something you'd even think about. My 2013 doesn't have an emissions diagram under the hood, so I'd find it REALLY unlikely to ever pose an issue. On top of that, cars aren't even put in the air during a standard smog check.
4) The "sniffer" is now dead and gone for newer cars in CA. Even one less reason to worry about messing with the 2012+ X-pipe.
To 2012 Cat Questions?
Quick Reply: [ZR1] 2012 Cat Questions?
