[ZR1] Led tail
I bought mine via Amazon.com. Just go to Amazon.com and enter a search for Corvette C6 led tail lights. There will be several choices come up. The first ones you see list for about $469, but if you scroll on down there are some on there for $303. I bought a set of these and they are the very same ones that others are selling for $469. They fit great, look great and work perfectly. I have received many compliments about them and especially on a black car.
it takes about20-30 minutes for all four lights. It is a simple plug and play type product. One screw for each light..it's one of those star tip screws..remove it, pull the light out from the top..there a couple of ears or tabs that hold the bottom in place. When you get it out simply twist the original bulb out of the socket and remove the bulb then plug the new light into the socket where you removed the bulb from. Test each light before re installing them as they have a dedicated + and - pole, so if isn't working pull the plug out, turn it 180 degrees and plug it back in..you have a 50/50 chance of being right the first time. It is one of the easiest mods you can do to your car. Drop me a line if you have any problems.
