[ZR1] Brake and clutch fluid
Hi.
Can I use DOT5 for brakes and clutch?!
On cap for clutch reservoir I have find DOT4 and DOT3 on brake cap reservoir, can I use DOT5 for both?
Go with a good DOT 4 fluid, I put ATE blue fluid in mine for brakes and clutch. Also put in "Speed Bleeders" at the same time.
Speed bleeders allow one person to bleed the brakes without getting air in the line.
See www.speedbleeder.com
Note there are 2 bleeders per wheel on a ZR1 or Z06.
