[ZR1] Hennessey HPE700 Question
I had their kit on my 2009 ZR1 without any issues at all. I kept in touch with the guy I sold it to for about 18 months after and he never had a problem with it that I am aware of. Last I knew it had about 13k miles and still running good.
Hennessey has a shop within 40 miles of my house. Most of these upgrades require a tune that can't be done in my driveway. Yes, they are pretty expensive but I may not have much choice. I am in California and the 700 is smog compliant here. That is pretty important to me.
Lingenfelter can also email tune your car.
Its also smog compliant as well and will make more power.
As I stated before- it's also much cheaper.
Good luck, sir, with whatever you decide and make sure to post your results here!
not directly but there are a few options, katech makes a larger heat exchanger, cooler logic makes a larger heat exchanger with bigger fittings for increased flow and offers a pump, veangence makes a kit with a pump and heat exchanger, or as another forum member as done he fit another stock heat exchanger above his current one and essentially did a dual pass set up
So far Hennessey is the only package I've found to be California emissions compliant. This is the downside of living out here. If it won't pass smog I won't be able to get it registered or sold if need be. I would also like to do headers but there aren't any long tubes with a carb number.
