C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] burning rubber smell
Old 12-03-2013, 11:24 PM
viperZ06
Support Corvetteforum!
viperZ06's Avatar
Default burning rubber smell
no it is not from doing burn outs . When I drive my car for 30 minutes or so, whether spirited or not, when is return to my garage I smell something that smells like hot rubber or burning rubber near the back of the car. Doesn't smell like clutch but I am not sure. Any ideas?
(A couple of weeks ago I ran over a piece of tire in the road
suppose that bent something too close to the exhaust?)
Old 12-03-2013, 11:49 PM
RPO_Z06
RPO_Z06's Avatar
Cruise-In III Veteran
St. Jude Contributor
Are you sure you don't have a chunk of tire stuck to or above your exhaust? I ran over a bag in my old Z06 once and it stunk like plastic until I got under it and scraped it off the top of the X-pipe, I just about never found it even after looking for a while on the lift.
Old 12-05-2013, 12:19 AM
viperZ06
viperZ06's Avatar
So, I must a alone in this issue.
Old 12-05-2013, 04:03 AM
LloydP
LloydP's Avatar
No I have it almost every time I return to the garage. I have looked and smelled underneath. Seems to be stronger around the mufflers but couldn't find anything in particular. I also had a similar issue on my 06 base C6.
No help here.
Old 12-06-2013, 10:42 AM
Glenn Quagmire
Glenn Quagmire's Avatar
I have the same issue, and like you, am not sure what the cause is. If I had to guess I would say clutch.
Old 12-06-2013, 12:31 PM
titletaker
titletaker's Avatar
I forget the name of the stuff, but my wife uses it at her work and its a residue from an adhesive used in the car. Smells toxic for about month or so, then it's all good. I had headaches, so drove with windows down and kept a fan going in my garage.
Old 12-06-2013, 10:07 PM
TSLAVette
TSLAVette's Avatar
Where's Chevy Customer Service when you need them on the forum???!!!
Old 12-20-2013, 07:12 AM
nykbob
nykbob's Avatar
Me Too...
I have this same type of smell when I return to my garage, but only after some mildly spirited driving. If I get on it even once on my 8 mile drive home, I get the smell. If I drive normally, nothing.
Tires? Puzzling to me as I'm not stomping it, so the rear tires are not breaking loose. (I don't think.)
Could it be clutch? I have no idea what that would smell like anyway, and why should that happen? How could you check this anyway?
Breaks? I doubt it as I don't think I'm applying the breaks hard at all during most of my driving.
I'm open to suggestions.
Old 12-20-2013, 09:22 AM
The boss
The boss's Avatar
No leak of any fluid that may reach the exhaust?
Old 12-21-2013, 04:54 AM
ZIE06Bernie
ZIE06Bernie's Avatar
Yep mine is always like that even after a long trip of normal highway driving. NFI what causes it but certainly not clutch or engine and smell is still just there after 5 years so mustn't be anything serious.
I suspect it is those wide rear tyres tracking around corners and being so wide causing scrub and hence the smell but certainly not stressing me. I have moved past sniffing my rears like some mongrel dog each time I get home as I truly think it is nothing serious.
To burning rubber smell
Quick Reply: [ZR1] burning rubber smell
