[ZR1] Looking for real world experience on INVO vs. stock Michelins
1 Post
Cruise-In III Veteran
St. Jude Contributor
I thought I'd ask here in the ZR1 section because I'd really like to know what opinions people here have of the Nitto INVO over the stock tires the ZR1 came with, either the Cup or the PS2?
Ride, grip, tread life, etc.
Jamie
Jamie
The Invo-
Rides better
Is quieter
Way better traction
I had Cup tires on my viper and put Invos on it also. Invo was better all those departments as well.
I'm guessing the cup tires might have some advantage for road course guys but it seems they go from really crappy traction when cold to pretty good when they are warm to really ****** when they get hot.
I drive my car a lot so ride comfort and road noise are important. The Invo excels at this and is one of the better hooking tires IMHO.
I have no experience with the Invo's... but all tires I have tried, cannot compare to Michelin PS once 'heated up'...
I'd be surprised to see an Invo out perform a Michelin, but it could be worth a try.
Thanks,
Dave
Thanks,
Dave
1 Post
Thanks RCC, this is exactly what I'm looking for, anyone else?
And Dave, your right about the heat cycle and the PS, they get it on once up to temp.
I put 10,000 miles on my OEM Michelins and then changed wheels and put the Invo's on them. As previously stated...better ride, quieter, traction and the best part is the car doesn't do any steering hunting...or what ever you want to call it. The Invo's track true and straight. The Michelins were much harder to drive with. I don't track the car, so I can't help you there, but when it comes time to replace these I will go back with the Invo's.
But it seems the Invo may be the better 'daily driver' tire... based on these posts here, I might be willing to consider!
Are they as light as the Michelin's? If I knew i'd save a few pounds rotating mass, that'd be a plus as well.
Thanks,
Dave
i had stock Michelin's on and switched to invos and as previously stated, ride quality improved, traction went way up (in stock form it would hook second no problem and the top of first) and they were cheaper.
1 Post
Actually you can get Invo's for less than $1,600 shipped right now which is over $600 cheaper than the Cup tires and $700 cheaper than the PS, granted they aren't run flats and you will loose that security blanket, but I don't really care about that personally because every Corvette I've ever owned was infinitely better when I removed the run flats and went conventional tires.
As for weight savings I can't find any information on that as of yet but they would have to be lighter but by how much is a great question.
The reasons above are why I even asked this question in the first place, I work for a large tire company but they only make half of the sizes I would need for the ZR1 and plans to make the others aren't in the near future.
I havent ran the Innvos yet but to hell with these Cups. They may be awesome on the track but the lane searching and the violent jerking when turning at low speeds is too much to deal with for a street car. Along with that they sling every grain of sand into the fenders and its enough to drive one crazy.
FYI Guys the new C-7 Z06 will come with Michelin "Pilot Super Sport" tires in the same size as the C-6 ZR-1.
1. They are run flats
2. They have 12-14% more lateral grip than the PS-2
3. They have a tread wear of 400! They are using the same compound on the outer edges as they use at Le Mans. So they wear a lot longer.
1 Post
Okay, I have a set of Invo's on my '10 ZR1 for street use only. They are pretty quiet, ride nice, and have decent straight-line grip. However, for track use they are a significantly inferior tire to any of the Michelin tire models (PS2, Cup, SS, etc.).
I have a dedicated set of track wheels/tires (actually two sets), so the Invo's are perfect for around town for me. PLEASE NOTE: The speed rating on the tire is NOT sufficient for a top speed run. So, take a very close look at that if you plan to drive near the top speed for whatever reason.
I think the better straight line traction of the invo is most likely because they are not run flat and have a softer sidewall...thus ride quieter and softer...
The Consigliere
Received 5,432 Likes
What size on the Invos to avoid throwing codes/confusing the computers?
Doesn't seem to be stock sizes.
