[ZR1] Reduced Engine Power
Hello all! Was just out for a drive and after leaving a traffic light and lightly accelerating the check engine light came on and dic posted Reduced Engine power, Service Ride Control, Service Traction Control. Was wondering if this ever happened to any of you. I have a code reader and could clear the codes but not sure if this would correct anything. If it's just a communication issue with computer it might but if there is something else wrong I might be making it harder on Tech when I take it in. Feels like its zero to sixty in about 15 minutes now! Thoughts?
There are a number of these issues reported on C6's to include our ZR1's. I would pull the codes and see what they are. In my ZR1, I have been having "low voltage" codes for the last few months - sometimes I have to shut off the car and restart to clear 3 or 4 times and then the next few days nothing. I recently had my car into a well respected shop here in Phoenix and they reviewed all my charging system, battery, (has newer battery) etc. Battery was 118% for a couple of days they had it as I do keep on battery tender - bottom line is somewhere I have a ground issue and/or sensor that is picking up low voltage for a split second that causing the reduced power and service active handling, etc.
I know others have had issues with everything from a sensor on the floor throttle assy, tele wheel, spark plug/coil wires, gas cap to the ECM, etc. etc. So, you need to know the codes. I would do an advance search here for C6's and you can read all the threads.
Good luck and let us know what you find! Other than having to reset my car by turning off and on, my car is great so now that I know what the codes are does not bother me that much.
Good luck! Ron
Good luck! Ron
Good luck! Ron
Good luck! Ron
ok, read the code. P2122 throttle position sensor. I cleared the code and now car runs fine. Don't know how long this will last but at least now I know what it is. Put battery charger on it to be sure there is a full charge. Hopefully just a glitch.
Ok, new update. Took it for a ride and 1/2 mile from house it crapped out again. Going to shop monday morning!
Fixed! They replaced the gas pedal. Tech says it happens often not only in Corvettes, but in the rest of the line up of cars and trucks as well. Something goes wrong that causes the parts to not talk to each other properly. No more reduced engine power
Another up date! Picked car up last Monday. Was fine going home. Took it out for a drive today and it threw the code again. I guess they didnt fix it. Back to the shop
William R.
Chevrolet Customer Care
Sincere apologies to read about the recurring concerns with your ZR1. I can understand how concerning this matter would be. I would be happy to communicate this situation with the designated Customer Experience Manager at your dealer if necessary. Feel free to message us privately if you'd like to proceed, or discuss this situation further.
William R.
William R.
Special order wires to re do wiringing harness. Seems that they are so thin that a good connection sometimes is not made. Takes 3-5 biz days for wires to come in. So maybe in a week it will be fixed
Thanks for asking. Car has been there since last Saturday. They still don't know whats wrong. They say they are in contact with engineering dept at Chevy trying to track it down. When car went back into limp mode last Saturday afternoon I went back home and called dealership. They said of course bring it back in. When I drove it in ( dealership close to home) it was back to running fine. So it is intermittent. Thats what makes it hard to fix. They have not been able to make it go back into reduced power mode since its been there.
Really sorry to hear about that. Intermittent concerns can be definitely be very tricky to identify. Feel free to keep us posted on the diagnosis. Your updates are appreciated.
William R.
OK, Here is a update. Car has been back in the shop for 2 weeks tomorrow(Saturday 6/28) GM Tech told dealership (over a week ago) that the problem lies in the wiring harness. Bad connections and too small a gauge wire. They will not replace the whole engine harness as the problem may still be present with new harness. They said the fix was replacing 3 particular wires in the harness and their connectors. The new wire is a upgrade to the wires that are in the harness. They had to special order the wire. Took about 6 days for it to come in. Today(6/27) the car is on the lift to do job. Tech finds out they don't have the proper connectors in stock. They have to order them. Should be in by Monday( 6/30) so looks like sometime next week. Wondering if any other of you have had this problem? Also wondering if this is going to fix it. Replacing the gas pedal didn't fix it. Thinking if this doesn't work how long will it be in shop next time? Wonder if it could of been as simple as replacing the ecm? Car is bone stock by the way. Thank goodness.
I don't recall reading about this specific issue previously here on the CF...anyone else familiar with this problem ?
sounds quite unusual to me...
OP, good luck and hope the dealer truly remedies the problem.
Sorta. They say its these three particular wires that need help. And when I say "they say" I am talking about GM tech. They told dealership tech what and how to do it and said it would be a better fix than replacing entire harness. We will see.....................
