[ZR1] Who sells a stroker short block for LS9?
I havent found many options:
1. LPE 417 short block - $10,250.00
2. Katech 416 short block - $14,400.00
418 LS9 rotating assembly from Texas Speed is $3800.00 and a brand new LS9 block is $3300 but I dont know how much I will spend on having it machined, assembled and balanced.
Any other options out there?
If you want more power you need to bump compression. Either go with milled heads or domed pistons.
I would buy a factory LS9 motor before buying any of the aftermarket bigger CI motors. The LS9 has proven itself to be very strong. If you decide to have a motor built IMHO it's important to actually be destroked- meaning have a bigger bore and short stroke. It's makes for a rev happy motor and cuts out some of the low end torque.
RedZ4me (06-20-2023)
If you want to stay with stock blower, I agree more cubes isn't going to help. If you want to swap to a different power adder later, go for it.
ls9 block/etc doesn't matter once you start swapping the bottom end out. Any LS gen IV motor will work. Hell do a 5.3L block built to a 427 if you want.
Yes, assuming you use the correct style crank for the dry sump system to work, or convert to a wet sump.
