[ZR1] Mods
Mods
Anyone running this on the ZR1?
I was thinking of ordering and adding that the brick mod and headers and a Tom Wong tune!
Is this a good way to go
http://www.lingenfelter.com/mm5/merc...E#.VBoyYrl0xdg!
Lots of us have that. If you are going to drop that coin I would order it differently. I would drop the shroud cover and go with a 2.35 pulley and 2 metco 50mm idlers. And I would port the snout to a 102mm and get a 102mm tb.
You will make a lot more power and add in the Vengeance HX and pump. Car will make great power and be reliable.
I offered up the lpe air intake at a killer price since I went to a custom larger intake but got no reply. If anyone else needs one it only has 3k miles on it.
Former Vendor
Might want to look at Flow Vs pressure instead of just raw flow #s..... We have tested both pumps IN THE CAR and logged IAT2s. Rest assured if the stock pump performed better we would not waste our time upgrading the pump.
I have done a lot of track and street testing on both and the IAts were as close to identical as I could get with out a controlled enviorment.
