[ZR1] Zr1 drag radial help
I've been looking into these same options.. I was considering a set of new forged wheels, but I want to keep the 19/20 wheel size.. Would the nt05r work on a 20x11? And just get a 1" spacer for the rears? Thanks! -Seburn
New for 2015 ---expect May-June timeframe....
New 20 inch drag radial that fits our stock rims.
A D.O.T. approved STREET tire which provides excellent traction at
the STRIP
• Proven Polyester-ply, steel belted, tubeless radial
construction provides strength & durability for
excellent ride control on the STREET
• Proven R2 compound provides quick and consistent
traction at the STRIP with little burnout required
• Minimal tread void for excellent dry traction,
strategically placed to aid in hydroplane resistance
• 18 popular sizes available for 15- to 20-inch
wheel diameters
Mickey Thompson
ET STREET S/S(STREET/STRIP)
Part #3400
P335/25R20 26.6 overall diameter.
Here is the sales PDF.
http://mickeythompsontires.com/adart...Sell+Sheet.pdf
the STRIP
wheel diameters
Mickey Thompson
Part #3400
the STRIP
wheel diameters
Mickey Thompson
Part #3400
the STRIP
wheel diameters
Mickey Thompson
Part #3400
Thanks man. i am going to do that too for now. Do they cover the rim or is the rim lip stick out a bit? I am going to hold off on the 18's for a bit. Ill try to pick some up used when i find the right deal. I heard from Marlon you made 672 with e85. Nice!!! I know it is cold out but do the nt05r hook at all in first and second. I image in first not so much. lol
As far as the 305s I'm not sure, I just went with the 275s since I like the NT05s and didn't want to chance any rubbing issues
If I buy replicas in 19X12 with the 345 Nittos, do I need to change the stock front tires? Also, does the absence of tire sensors create a problem? I'm new to this and know absolutely nothing about the tire sensors other than they tell you a tire pressure is low. Thanks.
