C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] just back from the dyno
Old 12-04-2014, 12:26 AM
K B Vettin
K B Vettin's Avatar
Default just back from the dyno
had my car tuned by Tom VanVugt and it is running perfect. low end drivability is perfect and power is through the roof. here's my list of mods and dyno sheets.
91octane 721WHP/689TQ
91ocatne + Meth 744WHP/705TQ
Race Gas 783WHP/741TQ
LPE intake
4 inch intake tube
S&B air filter
Nick Williams 102 TB
Installed flipped to prevent closing under WOT
LPE ported snout
Snout is port matched to match NW 102 TB
LPE blower pulley
2.35 uppper pulley, stock crank pulley
Fast 85lb injectors
NGK TR7IX plugs
Custom Cam Motion Cam
236/250 .629/.629 on a 117+3
LPE LS9 Ported heads:
American Racing Headers
1 & 7/8’s, with hi flow cats
LG
High Capacity Radiator
D3
Heat Exchanger kit
D3
Dual Spal fan kit
Intercooler brick mod
Aquamist stage 3 dual nozzle Meth Kit
Elite engineering dual catch can set up
Elite engineering thick tunnel plate
red is race gas, blue is pump
Old 12-04-2014, 01:50 AM
Dave Schotz
Dave Schotz's Avatar
Nice pulls KB!!! Yeah, Race Gas makes such a difference! were you using Meth on the Race Gas pull as well, or does it not need it?
Peace,
Dave
Old 12-04-2014, 01:59 AM
K B Vettin
K B Vettin's Avatar
Peace,
Dave
No meth with the race gas. My meth kit is set up to spray the minimum and only at WOT. I'll never run the 91 + meth tune, I just don't trust it. I'm spraying for cooling and octane boost/knock suppression.
Old 12-04-2014, 06:53 AM
narush
narush's Avatar
Great numbers indeed - I bet you won't run the 91 any longer now that you have the race gas
Old 12-04-2014, 07:19 PM
venomws7
venomws7's Avatar
Great numbers good work and Congrats
Let's see some videos
Old 12-04-2014, 08:30 PM
Dave Schotz
KB, can you post all the numbers in SAE? Or is the bottom SAE the best dyno pull in SAE?
STD will falsely inflate the numbers based on weather and elevation.
Thanks,
Dave
Old 12-04-2014, 08:40 PM
K B Vettin
K B Vettin's Avatar
Thanks,
Dave
i will ask the tuner for the graphs in SAE. the second graph in SAE is the 91+meth pull.
Old 12-05-2014, 07:23 AM
billy z06
Support Corvetteforum!
billy z06's Avatar
Great numbers
Old 12-05-2014, 11:38 AM
Brandon619
Brandon619's Avatar
Very nice Kris, I'm going have to stop by here in the next few weeks to check out your new upgrades!
Old 12-06-2014, 11:17 AM
JetstreamGS
JetstreamGS's Avatar
Stout #'s indeed. What race gas are you using to allow you to run cats?
Old 12-06-2014, 11:49 AM
K B Vettin
K B Vettin's Avatar
F&L oxygenated unleaded extreme 100 . it's not harmful on cats or 02 sensors and it sure does smell good!
To just back from the dyno
Quick Reply: [ZR1] just back from the dyno
