[ZR1] Battery Charging
Battery Charging
Hey guys,just got my ZR1 on Monday and need to charge the battery. I read the posts on the forum about removing battery or at least disconnecting to charge but why can't you leave the battery in and charge from under the hood at the "jump" connection from the factory? It would seem if it is OK to tie in another battery to the system here the current from a 2 amp trickle shouldn't hurt anything,correct? The manual says nothing one way or another on the subject so maybe some guys could chime in and answer this ... Thanks Rich
I leave my GEL battery connected and on a trickle charger everyday and it works great. Have never had an issue BUT that damn battery will die in a few days if not charged
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
I wouldn't suggest using a trickle charger because you run the risk of overcharging the battery.
I would suggest buying a battery tender. They monitor battery voltage and only provide current when needed. CTEK is a great brand to use.
