[ZR1] Oil cooler upgrades
Oil cooler upgrades
Has anyone taken any steps to upgrade the oil cooling capacity of their ZR1? I'm just looking at different means of keeping heat out of the motor during the hotter summer months here in Houston. I track the car and have significant cooling upgrades but I'm still pretty sure that I won't be able to track it during the summer.
I was at TWS this past weekend for an HDPE and the car performed flawlessly. It's currently making 681/613 at 10 lbs of boost, which is intentional. I don't want more power or more boost because they both equal more heat. Lots of port work has allowed me to drop boost while still running the 2.6 pulley. The car originally made 608/610 on the 2.6 pulley, which was how it was set up when I bought it.
I'm reasonably happy with the combination I've put together but started to see higher oil and IAT2 temps on Sunday in a session where I was pushing the car hard (for my driving capabilities). I saw oil get into the high 280's F and IAT2 was as high as 143F. Water was running around 235F at the time. I have an LG radiator in the car, a maggie charge cooler with a Redline tank and KP racing fittings and hoses. The ambient temps where around 89F when she finally got hot. I did a lap behind some slower cars and short shifted on the straight aways, which brought the temps back down to 260's for oil and 124 for IAT2. That lap was 10 seconds slower than my laps where I was running hard. The track is 2.9 miles long, for reference.
The car did a 50 minute session on Saturday, with a 5 minute break in the middle, in slower traffic and performed perfectly. It was also about 5-8 degrees cooler on Saturday. Sorry, I don't have any data logging on my car at this time, just a Dashlogic plugged in to see IA2.
So, anyone install a bigger oil cooler?
I swapped to the LG Zr1 Rad and noticed a 10* drop in oil temps on the track... I run Sebring in the 98* heat, and will get to the mid 270's after 5 or 6 hard laps on a 700 whp Zr1.. I don't think there is really any cooling out there to run a sustained 50 minute session as our session are 25 minutes here... Running 50 min straight is asking for trouble
Sunday when the car got hot was only a 22 minute session, they were cutting time because of the number of groups. I already have the big radiator and just about everything I can do to the charge cool system so, I was thinking the oil cooler is all that is left, in stock configurations right now. The other option that has crossed my mind is to weld some fins on the Redline tank and try to direct a little air flow past it to increase charge cool capacity, much like a finned differential cover.
Your iat2s are still good at 143*
Wrap your oil lines from your sump to motor. They pass really close to headers. Every little bit helps...
TikT makes and external oil cooler I believe
Would there be any value in a reprogrammed Stewart pump in my application?
Going to an lsx block from the stock aluminum (and not being able to run the factory oil cooler due to the location being different on the lsx than stock) we fabbed up a oil cooler using the Lingenfelter universal plate that uses the port above the oil filter and ran some lines up and mounted it I between my d3pe heat exchanger and the radiator/ac condenser. Temps dropped 30 degrees from what I was seeing peak with no cooler hovered around 225. Now they stay between 190-210 under abuse.
Nice set up, thanks for the pic and description of the added oil cooler. Running the maggie, I don't have room to mount the cooler there but perhaps mounting that cooler somewhere else under the car and putting a small electric fan on it will accomplish the same effect.
