[ZR1] What do you use for wax?
I'm sure most of us have been through the products through the years of waxes, cleaners, and what you like best.
I have used numerous Griot's Garage stuff and recently a few products from Autogeek.net for numerus cars.
the top end carnauba's from autogeek can get pretty pricey but if they are noticeably different then I'm in.
Any experience with their Souveran Paste Wax? ($95 for a kit) or Griot's Paste Wax ($39.00)?
Many still swear by good Meguiars' stuff which are good...used them.
Your choice?
In my case, paint is in perfect condition, driven in no rainy conditions in SoCal. Color is Torch Red. No need at this point for clay, polish or cleaner as such.
Your choice?
Your choice?
Your choice?
If you have swirls, smudges or fine scratches use Meguiars Ultimate Compound "Color and Clarity Restorer". This is an extremely fine chemical cutter safe on clearcoat and I can guarantee it will give you a mirror reflection finish. I have tried so many different products and nothing I can find is remotely better than this.
Once you have the mirror finish use the Meguiars Tech Wax 2 (purple bottle) which is a polymer product to give and keep that deep flawless show car finish. What an amazingly simple product to apply - I use it about every two months but then I am a fanatic.
Both these products wipe off extremely simply with zero residue. And best of all they are cheap and last for years - there is no need to use large quantities.
I realise you say your paint is in excellent condition so try shining a small LED headlamp directly into the paint from about 6 inches away as that will expose the slightest smudge or imperfection and if the reflection is not perfect, use the polish first because it makes a huge difference.
Not every Meguiars product is perfect but these two are stunning.
A couple of photos are on my garage.
If you want a mirror shine to "see your face in" this method will achieve exactly that.
Regardless, it sounds like you love the results and consistency of the Tech Wax 2.
I have used a myriad of products but my typical "go to" wax is zymol...it can get a little powdery upon removal if you apply to thick but it leaves a shine that is deep and rich. I have the monterrey red metallic paint and it has that deep color like it's actually a fluid.
I agree with two of the comments above. First, you would probably benefit from some paint prep. Also, Zymol is my go to product. I think it also depends on if you want really shiny, or a very deep shine. Many are happy with clear bra for instance, which enables you to get the car very shiny but lacks depth. The difference is slight, but significant if important to you. Think about the difference of looking at Art through clean glass v no glass. My experience is Zymol gives very good results although it alway amazes me that it takes a few hours to "set". Initially does not look much different. We have done same paint color side by side. My best results have been with Zymol concours glaze. Very expensive for the container but not so much on a per wax basis. After it sets, it is not shiny, it has a very clear reflection and a lot of depth. Again, depends on what is important to you. The prep is really important. If the car is a few months old, clay and a very light swirl remover are likely to improve the results (use LED test recommended above to determine if you need swirl remover). Good luck.
PS - I am sure we will get some responses defending clear bra and synthetic polishes and they do get very "shiny" results. In my opinion, this is the same way looking at something through a pice of glass makes it"shiny" but reduces clarity.
This Vette is a '10, 4700 miles in SoCal and always garaged. I need to do the LED test to see if it needs prep. Got the car and started a new job so time with the car until this weekend has been minimal.
To answer your question, I like depth of shine vs just being glass like shine. I like the art analogy.
I use HD Poxy which is a Hybrid Sealant/Wax which has a much higher melting point as opposed to carnuaba wax, theres a bunch of distributors in So cal that sell it. Look on 3dproducts.com to find one by you.
Also anytime you wax a car you should clay it or atleast do the baggy test the paint has no contamination that needs to be removed by clay
I'm still a fan of Zaino. For mass market products Meguiars has come a long way. The new "Ultimate" line is like a mass produced synthetic wax like Zaino was making over 10 years ago and I use a combination of both products on my cars.
I have used Zymol Concours back when a used Ferrari Dino GT in Fly Yellow could be bought for $20k in excellent shape...aging myself. Good stuff but I remember how tough it was to remove. Maybe they have improved that in the modern day but yeah, always been pricey.
Good luck. Glad you liked the glass analogy. Seemed consistent with what my eye sees as the difference in some of these products particularly comparing a quality wax with a silicone based product.
LGK do the LED light test - I use a very bright single LED which works just great - it will give you an instant proof of whether your paint is perfect or needs work. The slightest blur or marks will stand out like a beacon. If the image of the LED in the paintwork is not a perfect reflection then your paint will need work. Once you have the mirror finish, maintaining it with techwax is a 30 minute job every so often.
And by the way the Ultimate compound is such a fine chemical cutting medium that use on the clear coat of the Vette will give you that perfect deep shine and in no way damages the paint because it is NOT an abrasive product like old cutters which scratch crap out of your surface. And best of all the work required is way less than other products BECAUSE it wipes off with a microfibre cloth and zero drama.
Cheap excellent and perfect finish. Price is no gauge of quality.
PS Don't use Meguiars Leather products - they are not a patch on other brands eg like Mothers.
OK..several very enthusiastic testimonials going on here on fav's. That settles it...I need to buy 3 Vettes and try one on each.
(Any excuse I can find!!)
Though I guess if we're *just* talking wax which you apply by hand anyway, yeah it's great stuff.
I use ADAMS products these days. I have a flex polisher and use the microfiber pad to start and finish with fine machine polish and white foam pad. I use their "buttery wax" because it goes on easy and comes off easy. Underneath that I use their spray on quick sealer (machine super sealer takes 24 hours to cure and I don't notice any difference in protection). Stuff lasts all winter on my outside car.
I know a few people who use the Griot's stuff and I'm sure it's great but I have no reason to ditch what works well for me.
OK so here is what wasn't mentioned with any detail (pun intended).
Assuming no swirl marks in the paint to remove:
Griot's Fine Hand Polish
Finish with Griot's Best of Show Wax
Both Liquid.
If swirl marks, have used their #3 Machine Polish first. (Or clay before that if needed).
I have plenty left of both polish and wax from past jobs. I think the shine is average. I have used them on white to grey to blue to black cars and they seem to lack depth and the wax is not easy to remove. they may be better for the paint than the shine they produce which is not a terrible thing.
No problem leaving them to do my wife's daily driver (sorry honey)...
Both Liquid.
I just did my Black ZR1 with Pinnacle compounds and Zaino on top. Here are the results.
About 6 months ago, after restoring an original 1940 Chevy Master Deluxe Coupe I left the original black 75 year old factory paint as is. The final wax for that (after compound, glazing and polish) was the DP Max Wax from autogeek.net. It did a fantastic job for both depth and shine considering the paint. I will use that to finish this off for now.
(By the way for a test, as much as I have always loved Simichrome for metals, I tried the Ultimate Compound on the exhaust tips...in and out. I was surprised what a great job it did even on that.
