[ZR1] Damaged Carbon Fiber Side Skirt
I damaged my drivers side Carbon Fiber Side Skirt and are wondering what is the cheapest way to fix or replace it?
The factory skirt is over $2,000.00 which one body shop says they cannot repair but I see other places like RPI design that has a pair for $645.00 for both sides plus the cost of 11 rivets per side to install. The damage is a scrap about 6 inches long at the front.
What is my best option?
When I searched on ZR1 side skirts there seemed to be a few choices considerably under (thank God) what you stated as the price.
Seems there is subtlety between "ZR1 style" and "ZR1 replacement" the latter of which I will assume is the desired choice.
Here are pictures of the scrape.[ATTACH]Attachment 47911514[/ATTACH]
Thanks for all the replies. Currently I am studying my options, either purchase new 100% CF skirts from RPI at $645.00 plus shipping or I sent this picture to a high end sports car body shop to analyze the damage and see if it can be repaired, check with a bike shop that deals with CF and see what they say.
Last time I scraped my front splitter (I was on my second one) I just sanded it down and threw some clear on it.. . Wasn't perfect - but hardly noticeable.
That's not too bad and it doesn't look like it into the fibers..
gl
gl
I do carbon fiber manufacturing.
As stated previously, as long as the number of spider cracks are limited and the depth does not reach the actual fiber, it can easily be repaired.
If there are spots that do reach the fiber, it can still be repaired to a much better state [really all depends on how picky you want to be].
Make sure a nice clear epoxy is used, using polyester or vinyl ester will 'brown' out the color of the weave. Additionally I recommend having the side skirt re-cleared or somehow protected from UVs. Otherwise over time it will yellow, embrittle, crack, etc.
If you were local, I would be happy to get this corrected for you. If you have any other questions or guidance, feel free to contact me.
Thanks for your response Chris, I had my son look at it and he wet sanded it lightly with out taking off the clear coat and said that the impact crushed the weave and it was the best he could do with it which is passable because of the location. However I intend on replacing both of the side skirts with the RPI Design skirts. I would be interested on your advise on the repair and replacement. Please see the attached picture of the repair
For clear coat:
-Tape off area so you don't damage anymore when sanding.
-Sand some more, not a lot or not down to the weave if you can help it.
-Smoothing with less and less grit, no water, wipe off.
-Spray some clear coat.
-Let it dry, light sand and recoat as desired.
-Now start the fine wet sanding and polishing, wax or whatever last.
The main difference will be getting clear coat on there, soaking into the cracks and damage, most of them will disappear. You can even flex the area a little during the first application to work the clear coat into cracks etc. It gets tougher when the damage disrupts or shifts the weave as others have mentioned. Yours appears to be an easy fix if someone wants to spend the time vs paying for new ones. Or fix and also buy spares for when you really smack em, hopefully not. Good luck.
