[ZR1] H/E plumbing leak?
H/E plumbing leak?
cooling mods
brick mod
KATECH H/E (hopefully swapped out for magnuson soon)
Fasterproms spacer
Fasterproms expansion tank
I seem to be leaking dexcool somewhere near the passenger wheel (looks like left side of expansion tank).
Here is the problem, the dexcool doesn't show up for 2-3 days after sitting.
I've tested it twice where I drive it hard and check above and below for anything wet, all the expansion tank fittings seem fine and everything seems dry. 2-3 days later we have a piece of bread sized pool of dex.
thoughts?
brick mod
Fasterproms spacer
thoughts?
Things expand when heated so it probably seals up when you are trying to test it. I would just snug everything a bit when shes cold.
