C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Do any of you guys who are using this Heat Exchanger have pictures of how you mounted it? I can ship it if necessary to have the mounts welded on as well.
Dude i did much better than the tiny brackets, I got 4 aluminium bolts, cut the head and 2 of them welded on the side at the bottom and 2 of them welded on the top of the I/C unit. all screwed up in the plastic shroud, VERY solid and before drilling the holes, you could choose the exact angle/positions you want!
