[ZR1] Just sharing some cool pictures of my zr1
#42
That's living on the edge. Why not plumb in a air-to-air intercooler core?
#43
Looks, and ease of install and fabrication.
But after popping the motor I do believe I need something to cool the charge. Will likely try meth injection before I try an actual intercooler
#44
Meth is certainly fine/effective...but then your car is essentially dependent upon it. If the meth system fails, potentially you have another motor failure. My personal preference...I'd never run a high HP turbo car without an intercooler. It's always in place, so its a bit more "set it and forget it" than say a meth kit with relays, switches, etc. Either way, its a cool concept.
#45
I wouldn't even think about an air to air mounted in the front bumper at this point.
I am constantly thinking about doing a intake mounted air to water, but haven't pulled the trigger just yet.. my main concern with that being mounting a water tank in the car. And having to listen to the pump and water slosh around when I'm trying to just cruise around.
#46
I had Turbo car for many years that had an air to air intercooler...front mount units can be very efficient, and I wouldn't hesitate to use one again if needed. But yes, you are correct that if you go front mount, you'll need to keep an eye on all the fluids that are also being cooled up front and are now presumably cooled behind the intercooler. Weight won't be that much of a factor; just some aluminum bits and pieces...especially with all that new found power now with a cooler/denser intake charge.
#50
Been thinking about mounting it under the car somewhere, but then would need to have some sort of extended fill neck to fill it every so often...
#54
I actually called to order it. But it was made to order and had a 3 month wait.. I'd rather just fab one locally than go that route and wait on theirs.
#55
#58
#60
Yeah man I'd get with AldoWelds. Fairly good price on them and it uses a Rule 3700 pump, pumps some major water lol.
