C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] High output alternator for 2010 c6 zr1
Old 08-29-2016, 06:27 PM
SickC7
Cruising
SickC7's Avatar
Default High output alternator for 2010 c6 zr1
im having voltage issues with my car, since i have alot of extra electrical mods, including triple pump fuel system, upgraded dual fans, d3 water pump, nitrous bottle heaters, etc. Does anyone know where i can get one in a timely manner? Ive researched but only stuff that comes up is for c6 6.2 7.0 not for zr1s. Thanks in advance! 2010 zr1
Old 08-29-2016, 07:04 PM
SquirrelyNutz
SquirrelyNutz's Avatar
Nobody makes an alternator specifically for the ZR1, you will have to make one work with some spacers and a different belt. I couldn't tell you the exact parts, D3PE installed mine. They could probably get you what you need.
Old 08-29-2016, 10:00 PM
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
Call amber at kp Racing. She has one for the zr1.
Old 08-29-2016, 10:53 PM
SickC7
Cruising
SickC7's Avatar
i will do that tomorrow! You speak from experience?
Old 08-29-2016, 11:08 PM
Gary '09 C6
Support Corvetteforum!
Gary '09 C6's Avatar
The LS9 displaces 6.2L...just has a SC on top of it.
Old 08-29-2016, 11:12 PM
SickC7
Cruising
SickC7's Avatar
Right, but alternator is different... Theres plenty of options for 6.2 and 7.0 but not for ls9.
Old 08-29-2016, 11:18 PM
Gary '09 C6
I suspect with your modifications you do need a unit with higher output...whatcop? gave you good advice. Let us know what you end-up with...
Old 08-29-2016, 11:21 PM
SickC7
Cruising
SickC7's Avatar
will do.. Im calling in the morning, hopefully i can find the fix to this. I keep killing batteries and my car doesnt run right when its pushed to the limit because of the lack of voltage to fuel pumps and coils i suspect....
Old 08-29-2016, 11:59 PM
C5 Hardtop
C5 Hardtop's Avatar
There is an old school test in the case where you are uncertain. Reproduce the problem at night and if your headlights do not dim, it is not a voltage issue.
For a sensible and more scientific test, you could measure the energy output during the problem scenario and validate you are low.
Another thing you could do is get the specs on these new parts for power draw requirements and add them together to see if your alternator has enough energy output stock to handle new power requirement. As a bonus, you'd know how much energy you need from the new alternator in the case the stock alternator isn't enough.
Old 08-30-2016, 05:53 AM
whatcop?
whatcop?'s Avatar
Gkzr1 has one on his car. He was having issues at high RPMs. I keep mine on a battery tender and have a brute of a battery so I haven't ordered the alternator yet. I did however speak to Amber about it and it was about 800 or 850 for it and put out 280 amps iirc.
Old 08-30-2016, 08:51 AM
Campfire
Campfire's Avatar
KP racing put one on my car. I was having trouble in the Houston heat with fans running full blast, in 100 degree temps, sitting in traffic. My voltage was dropping at idle, causing the car to throw a LOW VOLTAGE warning. Along with that, it would shut down the air conditioning and idle would go nuts on the car, hunting from 1500 rpm to stalling at the light. The alternator is custom made and I can't recall who they worked with it get it but it solved my problems and I know they have installed it on a few other cars as well with good success.
Old 08-30-2016, 09:49 AM
KENS80V
KENS80V's Avatar
The first and cheapest thing you could try is to increase the cable/wire size of the charge wire from the alternator to the starter motor.
Old 08-30-2016, 12:48 PM
gkzr1
gkzr1's Avatar
DC Power Inc makes the alternator and KP racing sells them. I have a lot of stuff, pumps, heaters, etc. drawing on my car. Running the bottle heaters at idle would push it over the edge causing all sorts of issues. Have had no issues since installing The new alternator.
Old 08-30-2016, 01:46 PM
SickC7
Cruising
SickC7's Avatar
Thats good to hear! I got one coming from KP.. Whats your voltage when all the things are turned on?
Old 08-30-2016, 02:00 PM
gkzr1
gkzr1's Avatar
Originally Posted by sickc7
thats good to hear! I got one coming from kp.. Whats your voltage when all the things are turned on?
14.0-14.1
Old 08-30-2016, 02:02 PM
SickC7
Cruising
SickC7's Avatar
14.0-14.1
Oh thats good, thanks.
Old 03-28-2017, 11:36 AM
screaminchevy
screaminchevy's Avatar
You would think after having KP do all the work to my car the first time (ice tank, fuel system, nitrous, dual fans) they would have put this alternator on as well, or at least recommended it. This explains my voltage issues. Par for the course.... Thanks Amber!
Old 03-28-2017, 05:10 PM
Victor Vargas
5th Gear
Victor Vargas's Avatar
isn't there an SSV, PPV Law enforcement version avilable off another GM product part # ? or this is non existing any more ?
Old 02-05-2018, 03:53 PM
0D3PE
Former Vendor
D3PE's Avatar
the MAST cylinder heads wont clear the after market alternator so we had to space it up with some billet spacers.
To High output alternator for 2010 c6 zr1
Quick Reply: [ZR1] High output alternator for 2010 c6 zr1
