C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Wtb ZR1 axle back exhaust?
Old 12-28-2016, 08:27 PM
gcolella
gcolella's Avatar
Default Wtb ZR1 axle back exhaust?
Looking for axle back ZR1 exhaust ?
Old 12-29-2016, 10:41 AM
pcguy2u
Support Corvetteforum!
pcguy2u's Avatar
Have had the exhaust off of my ZR1 at least once, and it seems like a pretty standard vette setup. But I have never figured out what the axle back reference means. What's the difference?
Nick
Old 12-29-2016, 11:44 AM
I brake for nothing
I brake for nothing's Avatar
Axle back just refers to teh rear most portion. ZR1 is specific if going back to original.
Old 12-29-2016, 12:00 PM
pcguy2u
pcguy2u's Avatar
So, I guess you're looking for a stock set of ZR mufflers that have not been cut.
FWIW, the rear most portion is the muffler and the integrated pipe that requires that the differential be dropped to in order to uninstall it. Either that, or you cut the pipe and rebuild a connection or weld it.
Old 12-29-2016, 01:41 PM
ufaj26
ufaj26's Avatar
It will come out without having to drop the rear end. sometimes easy, sometimes with a little extra grunt.
Old 12-30-2016, 10:07 AM
jtswenson
jtswenson's Avatar
What are you willing to pay? I have a set of them off my 2011 ZR1.
Old 01-01-2017, 07:53 PM
BearZ06
BearZ06's Avatar
Received 1,335 Likes on 775 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Removing the heat shield above the mufflers gives a little more room and helps a lot.
Old 01-02-2017, 08:18 PM
gcolella
gcolella's Avatar
PM'd you
Old 01-03-2017, 09:09 AM
rob62
rob62's Avatar
Received 1,733 Likes on 874 Posts
I have a set mounted on my wall. About 25 miles away too.
Old 01-05-2017, 06:00 PM
gcolella
gcolella's Avatar
what do you want for it ? I'll drive up to you
To Wtb ZR1 axle back exhaust?
Quick Reply: [ZR1] Wtb ZR1 axle back exhaust?
