[ZR1] 2012/13 X-pipe Question
Does anyone make an x-pipe that removes the 3rd and 4th catalytic converter on the 2012/13 while connecting to the factory pipes? If so, would they have to be cancelled with a Tech2 to avoid any codes? TIA
Red Devil (01-16-2017)
The X-pipe for 2012-13 IS different than earlier models. The flange locations and configuration is completely different. You want a Corsa 14331 X-pipe. It is a direct bolt on & is AFTER all the O2 sensors, so no adjustments needed for emissions codes.
If you're not in a big hurry, I may have one off my car for you. I already have a set of ARH headers here that I may put on in the next few months so the Corsa X-pipe will just be sitting here. Shipping will be a wash since I live a short drive south of you in western NY. Just a thought.
