Cartek SC A4 C6 makes 782 RWHP & 739 RWTQ.
Here are the dyno numbers of a 2005 A4 C6 with a D1SC on a stock CID Cartek built LS2 short block that we just finished. Without the belt slip between 5900-6800 RPM it should make over 800 RWHP.
And some specs.
Stock CID Cartek built LS2 engine
D1SC supercharger (16 PSI)
Cartek custom fuel system
Larger radiator and water pump
Custom air to air inter cooler
Kooks Headers
Stock 3.42 gears
Cartek custom 2.5 bar tuning
Julio
And some specs.
Kooks Headers
Stock 3.42 gears
Julio
Originally Posted by tekhombre
And some specs.
Kooks Headers
Stock 3.42 gears
Julio
Kooks Headers
Stock 3.42 gears
Julio
Peter
And some specs.
Kooks Headers
Stock 3.42 gears
Julio
And some specs.
Kooks Headers
Stock 3.42 gears
Julio
Damn , You guys just put one Procharged C6 in the 9's with less power than this beast , can't wait to see what this will do .
Hey , maybe you should change your name to " Cartek Supercharging " .
And some specs.
Kooks Headers
Stock 3.42 gears
Julio
And some specs.
Kooks Headers
Stock 3.42 gears
Julio
Scotty
Former Vendor
And some specs.
Kooks Headers
Stock 3.42 gears
Julio
And some specs.
Kooks Headers
Stock 3.42 gears
Julio
OpticZ
Originally Posted by E.A.
Great Numbers!!!!!!!
It's amazing to see what little D1-SC's can do, with the correct set up.
Talk about something that must be fun to drive, wow.
EA
EA
Congrats, Great Numbers!! Do you think that you left any power on the table by not using the American Racing headers or is the power difference negligible?
We have tested many header brands in various applications (we will leave the names out) and the result is always the same, we end up using Kooks. We have Kooks headers in all our record setting cars, from 10.5 @ 131 mph H/C C5s to this C6, the first to run 9s. The performance, fit and finish is top notch, and the company has been around for decades.
Julio
