P0101 out of No where. Please help if you can...
Guys,
The car has been great for months, no issues or codes then 4 months back the car would stumble, and have a sensation like it was "flooding" out. It was totally random upon engine start up, cruising steady at any speed, accelorating hard... totaly random under ALL driving or starting conditions. It does this Flooding stumble thing until it throws a P0101 code and then it's fine, Totally FINE, until it does it again. It will throw it almost every time I clear the code with a scanner if I do it on the fly, the code may take 10 seconds to clear if I pull over, and it may take 5 minutes. So far I have changed the T.B., M.A.F., M.A.P., T.P.S. on the accelorator pedal, and just put a new ECM in last night and went from LS2 edit to HP tuner hoping for a shot in the dark. As of last night changing the ECM and using a copy of my tune from LS2edit copied to HP Tuner the problem only got worse, now the car does this once a mile... If you have any help, It would be VERY appreciated...When the car runs it runs GREAT, I wish i could just get this one figured out...
Jeremy
Jeremy
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
I have found once or twice where the coils on the maf are covered with dust etc getting through aftermarket filters. Cleaned them off (carefully) and the code did not come back.
Problem is I've even put a new maf on twice... Can't figure this one out... I will take it off and clean it again for sure... Right now I'll try just about anything... Thanks Guys p.s. I'm searching for an unseen broken wire or short as well...
Jeremy
Jeremy
Seems like I also read that the oil used with aftermarket CAI's can sometimes coat the wires in the MAF causing them to fail. Especially if someone got over-entheuastic when oiling the filter. Good luck.
Big J,
Good stuff, you swapped to HP Tuners.
Your PCM is constantly comparing the MAF airflow with that of the VE table calculated number. This is to check the MAF operation. For FI cars this can cause an issue becuz the VE table only runs to about 21 psi (105Kpa).
To fix this you can increase the Maximum Delta Airflow - P0101 Error table so that the airlfow delta between what the MAF is reporting and the VE table is calulating can be larger and hence P0101 will not be set.
Go to: General Tabs/ Engine Diagnostics Sec./ Maximum Delta Air Flow; double the value or multiple the table by 2.
Are you still having issues with the "reduce engine power" - P1514 Error; double that value as well.
Good luck Bro!
Good luck Bro!
Originally Posted by Brabus2
Big J,
Good luck Bro!
Good luck Bro!
You are a TRUE friend Richard... You take the time to help a Brutha out while your sick in bed... Your the best bro... I'll check that as soon as my tuner gets back in town Monday... THANKS for ALL the help Guys!!!
Jeremy
Originally Posted by Mr.Big
Dude,
Jeremy
Jeremy
Hey Big J....I haven't heard from you, so I assume everythings OK. It's the least I can do buddy, you've been a GREAT help to me as well.
Jeremy
