Octanium – The Most Powerful Race Fuel Concentrate Available!
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It’s time for the monopoly to move over for a new and improved product! I’ve been watching and waiting for the development of this stuff for the last few months and it is now available to the public!
In 2006, a team of leading automotive tuners, drivers, and scientists came together with a single goal: create the world’s most powerful octane booster for gasoline powered, high performance vehicles. After countless hours in the lab and on the dyno, a powerful formula emerged: Octanium! No other major brand additive can match Octanium for true, measurable increases in gasoline octane. Using Octanium can raise 93-octane gasoline up to 100 octane; dramatically more than any other additive.
The proprietary blend of ingredients in Octanium is designed to eliminate detonation and pre-ignition by stabilizing and modifying the burn rate of gasoline and increasing the autoignition temperature of the air/fuel mixture. Octanium is the ideal product for high performance factory or custom engines that require the chemical properties of a race fuel to achieve maximum power and reliability. Octanium works great with high-compression normally aspirated engines and supercharged, turbocharged, and nitrous assisted engines. Whatever you drive, Octanium helps your car, truck, SUV, motorcycle, or watercraft run at peak engine performance.
• Comes in 32 oz. brushed aluminum container
• Treats up to 15 gallons of gas. Save $$$$ from race gas!
• Safe for oxygen sensors and catalytic converters
• Reduces hydrocarbon and carbon monoxide emissions
• Cleans injectors & combustion chambers of carbon deposits
• Lower cost on a per ounce basis than the competitors
• Independent lab tested, verifiable results. The only octane booster that will actually perform as advertised
For a limited time to introduce the product here are the prices! Shipping is outrageous these days so I will cover some of it.
One bottle - $21.95 shipped
Four pack - $72.95 shipped
Race Case - 12 Bottles (Buy 11, get the 12th at no charge) - $197.45 + $5 for shipping = $202.45 shipped!
In stock for immediate shipment!
Orders can be placed here or by calling 832-385-9622. Thanks! Jason
I tried some of this, it does work. I'm not a big fuel "additive" guy but after I tried it, I will definatley use it. My daily driver is a SC300 single turbo. On 93 oct I can run 18.3 psi on most days, hot weather I can run 18.0 without ping. I put a can of Octanium with a full tank of 93 and I can get away with 20.8 on the street. We hooked up a lap top and saw no timing being pulled until 21 psi. Running 2.5 more psi is about 40hp on the street. The stuff works.
SW
SW
And, I am proud to announce that Gulf Coast Performance is now a dealer!
