C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
MTI/HKE - F1C ProCharged 427
Old 06-17-2008, 11:04 PM
aTX427
Guest
Posts: n/a
Default MTI/HKE - F1C ProCharged 427
Old 06-18-2008, 01:13 AM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
running the stock cam?
Old 06-18-2008, 01:52 AM
o0 zeno 0o
o0 zeno 0o's Avatar
Originally Posted by john_sblendorio
Build Sheet:
Motorsport Technology Install and tune
HK Engineering 427ci Short block assembly
R.E.D. Darton sleeved 427ci LS2 block
Callies 4" crank
Compstar rods
Custom 9:1 Wiseco Pistons
Tool steel pins
GFX rings
Coated bearings
ARP studs
N-Motion dual roller
LPE oil pump
ECS 8-rib
RAM dual clutch w/ aluminum flywheel
Kooks 1-7/8" x 3" z06 headers
Custom HKE Blower Cam
F1C ProCharger
stock 243 castings
Patriot gold springs
Ti retainers
Old 06-18-2008, 02:09 AM
Mr.Big
Mr.Big's Avatar
John,
I wish I could talk you into a methanol system... Us Texas Boys REALLY need it...
Old 06-18-2008, 02:23 AM
o0 zeno 0o
o0 zeno 0o's Avatar
103F temps?!
Old 06-18-2008, 02:28 AM
Sportsdude
Sportsdude's Avatar
Congrats
Old 06-18-2008, 03:18 AM
MachineWorks
MachineWorks's Avatar
You can't go wrong with MTI!!! The guys there are top notch, hands down.
Billy
Old 06-18-2008, 03:33 AM
blu00rdstr
blu00rdstr's Avatar
Very conservative results, the motor is built to handle quite a bit more than 11psi. It's tempting to start comparing cubic inches and blower size and other setups.
Old 06-18-2008, 03:37 AM
VetteFish
VetteFish's Avatar
it seems you should be making that power at a lot less boost.
Old 06-18-2008, 07:07 AM
big bollas
big bollas's Avatar
Billy
True that
Nice numbers John
Now enjoy it
Old 06-18-2008, 11:15 AM
BrooklynC6
aka allbottle¬hrottle
BrooklynC6's Avatar
Location: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
Awesome build , now go out on the road and make us some Video !!!
Old 06-18-2008, 05:41 PM
Busa196
Busa196's Avatar
Nice numbers John . I hear ya on the heat.....FI cars are no fum in the 105 degree temps.
Old 06-18-2008, 06:05 PM
Mr.Big
Mr.Big's Avatar
John,
Everybody in the know... Knows how conservative you had to be on the tune, running 93 octane in Texas summer heat with no Methanol... We know your car has TONS of potential with lower IAT's and more agressive tuning... I'm VERY happy for you, It's gonna be a BEAST!!!
p.s. I'm happy to see you go with the ALKY system on your ride... VERY good call!!! V.P. M3 is my fuel of choice, I buy it by the 55gallon barrel, and a few friends chip in... it comes to $6.72/gal. If I buy it from the local speed shop, 3 gallons or more at a time, it's $7.50/gal, and 1 gal=$8.50... Cost is VERY effective. 1-1.5 gallons used per tank of gas. I just refill, each time I refill the gas tank...
Old 06-18-2008, 06:24 PM
Vindication
Vindication's Avatar
Congrats to your build. It sounds just awesome! It has been a long time coming and I'm sure its a great feeling to finally have your car up and running after the long wait. Enjoy it and can't wait to see some more vids.
M3 VP is good stuff. That is what I use on my car as well
Old 06-18-2008, 08:22 PM
schilitj
Support Corvetteforum!
schilitj's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
John
Great results and a well built motor. You have a beast and you WILL enjoy the hell out of it.
I just put a forged 402 stroker in my C6. Added back all my power adds: AFR225 heads, D1SC procharger, etc. First pull was 560/506rw with 3lbs of boost using the 4.75 pulley. Tomorrow doing a pulley swap, going down to a 4.25 and another pull, this time with up to 10lbs of boost. I will post the numbers after the pull.
I'm hoping for numbers like you posted.
Jeff
Old 06-18-2008, 08:29 PM
aTX427
Guest
Posts: n/a
Dam, Jeff - that is stout. I bet you are in the mid to upper sixes without a problem. I think there will be quite a few winter builds coming together over the next few weeks.
Old 06-18-2008, 10:40 PM
RICKEY BOBBY
RICKEY BOBBY's Avatar
I have been driving my car for a few days now and I am still amazed at how strong it pulls. Its going back soon for injectors and driver plus smaller pulley!!
To MTI/HKE - F1C ProCharged 427
Quick Reply: MTI/HKE - F1C ProCharged 427
