Features two 3/8" NPT female bungs. 180 degrees apart
* Internally Baffled
* Can be use as a remote crankcase breather tank with the installation of Moroso P/N 22635 Positive Seal Fittings
* Designed to be panel-mounted and comes with T-bolt mounting Clamp
* Comes with Breather No. 68815
* Dimensions: 3-1/8" dia., 6-1/2" tank height without filter
* Drain valve
My Norris cans are baffled. I decided not to use the Moroso because it vents to the engine bay, which vents oil fumes into the cabin. Check out my dual catch can set up on Dallas Performance's web site. It works great.
