C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
W/416 LS3 stroker: max psi w/1500 paxton?
Old 01-20-2009, 09:36 PM
SpinMonster
SpinMonster's Avatar
Default W/416 LS3 stroker: max psi w/1500 paxton?
Does anyone know the max psi you can make using a 1500 or 2200 on a 416 stroker?
Old 01-20-2009, 10:45 PM
greekc6
greekc6's Avatar
prob depends on compression too but i know the 2200 is good for 20-22lbs of boost effieciently. and the 1500 is about 17-18lbs. i could def tell ya as soon as mine blows up cuz that the route im gonna go.
Old 01-21-2009, 07:26 AM
SpinMonster
The 1500 will make 17-18 on a 416?
Old 01-21-2009, 11:16 AM
0Mike69@ECS
Former Vendor
Mike69@ECS's Avatar
Cruise-In III Veteran
Cruise-In V Veteran
You can make more with each head unit, but if you're looking to spin them harder than that, call Doug and he can set you up with a drive system to help maximize it!
Old 01-25-2009, 11:38 AM
0C_Williams@RPM
Former Vendor
C_Williams@RPM's Avatar
Spin,
I don't think the 1500 will be able to supply that 416 with enough CFM past 5800 RPM or so...my guess is the power will drop like a rock past that point.
Old 01-25-2009, 01:09 PM
EdwardETraylorIII
EdwardETraylorIII's Avatar
Spin,
I'd say you might even drop off as early as 5,200 RPM. That 416 will be moving A LOT of air up top!
Old 01-26-2009, 09:21 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes on 656 Posts
Depends a good deal on cam selection too, but I would think the 1500 would be a little small for a maximum effort build on a 416. It would make good numbers, and run a decent time in cold weather, but IAT's would get a little carried away in the warmer weather and drop a lot of ET because of it.
To W/416 LS3 stroker: max psi w/1500 paxton?
Quick Reply: W/416 LS3 stroker: max psi w/1500 paxton?
