which spark plugs should I use on LS2 FI car?
Hey Guys, Which spark plugs should I use on LS2 FI car? How often should they be changed...
Larry
Larry
Good morning Larry, I use the TR6's and regap them a little tighter than stock. I have the F1A Procharger and I have to regap them to .28??? I think that's what it is???
Former Vendor
for example, if we have a car at 20+ psi we will run it at .026 if we are at like 7 psi we would set it at .034. 10 psi around .030. make sense? the more boost the smaller the gap to help keep from blowing it out. most of the time you will be good to just set it at .028-.030 AND GO!
Thank you, makes sense. Figured that was the reason why but was more curious on the particular gap size to how much boost to run. Same principal from my nitrous days.
Wow thanks for the information guys. I installed mine at .030 before i saw the other post. will it hurt anything? No one has answered my question on what they would do with my car if it was theirs. I am looking for my next mod. this F.I stuff is like an addiction. LOL What would some of you do...
See above for car and mods already performed.
Thanks for all your support...
Larry
Larry
Larry
Larry
Anyone used the TR6IX which is the iridium version? I've had great success with the TR55IX standard copper plug upgrade, havent tried any FI with the iridium plug yet, but had wonderful gains with the other plug, plus alot better throttle response.
