Boost for D1 procharger
Is there a chart that will give you a guide line of how much boost you will make with what size pulley?
next question:
what is the smallest pulley you can put on the D1 keeping it under the max flow of 1400cfm?
next question:
I am sure some of the guys on here can come up with something for you. But boost is not soley based on pulley size. Boost is a measurement of restriction. The better your motor flows less boost is required to make the same power as a worse flowing motor. Your cam makes a big difference on the amount of boost you make. So to get you a straight forward answer of a 3.8" pulley will give you 10psi is just not going to be accurate. There are ball park figures that the vendors or a bunch of the guys on here can toss your way but dont expect them to be dead on when you install the system.
It's not the CFM you should worry about, it's the max RPM. The Max impeller RPM for a D1SC is 65,000 RPM and it has a 4.44:1 step up so the pulley can't be spinning faster than 14,640 RPM (minus a little less for safety's sake). The crank pulley is 7.37" in diameter. With a 6500 redline I get 3.33" minimum pulley diameter.
I did find this: http://www.exoticperformanceplus.com...html?item=1077
thanks
Former Vendor
