Timing, How much are you running on FI
How much timing are you guy's running on your FI setup?
If your running low boost (6-7 psi) what is optimal?
The outside temp here in Texas is HOT which I'm not sure if you would factor this in.
I have noticed a slight hesitation @ low rpms running the restrictor plate and the small pulley (3.2) that comes with the ECS kit. I think Shawn (Ragin Racin) is running 10 degrees timing but I will let him chime in to confirm.
Thanks!!!
Thanks!!!
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
Thanks!!!
Thanks!!!
There shouldn't be any hesitation? Unless you have an A6, they have a slight hesitation as it decides what gear to be in?
I'm thinking that the timing has something to do with it but was not for sure. It's just a slight hesitation in the low rpm as you can feel it under 2k normal cruising.
Correct.
How low of an RPM does it stutter at? At what RPM does it clear up? Do you have a cam and if so what are the specs?
Yea, if you wanna take a drive down to Pearland.
It's RR blower cam. When I come into boost, I can't feel it but my tires are on smoke mode. I was just curious as to why the slight stutter at low rpm. I guess it's the colder plugs an not so much the timing.
PS: Since I havent actually seen your car, this is just similar problems that I have had and since plugs are easy to do, its a good place to start
Former Vendor
Location: Greater Detroit Metro MI, when I'm not travelling.
I dont think they are too cold, its just they are copper plugs and the TR6s just seem to develope these symptoms. After using them on 10+ cars, they just act like a misfire after apprx 200-500 miles. Ive actually been using the Iridium NGK TR7IX's in the last few cars and they will go 1-3K miles before they feel like the car is misfiring/bucking.
If my car felt like it was misfiring unless I changed my plugs every 200 - 500 miles I would buy another car. This weekend alone I'm driving 1500miles!
Just because they "look fine" doesnt mean there couldnt be a problem with them...as a matter of fact, if they "looked fine", why did you replace them if you didnt have a problem with them?
Former Vendor
Have done dozens and dozens of FI builds over the years with TR6's and have not seen this issue.
But I do agree that plugs are always a great starting point for diagnostics in a situation like this.
However my first starting point would be to have the car logged and check O2 sensors for proper activity, check LTFT and STFT for bank to bank consistency, total advance, etc.
