Experience with P1SC unit VS P1SC-1
Former Vendor
P-1SC Impeller:
P-1SC-1 Impeller:
P-1SC Impeller is run more on trucks it comes in quicker for low tq but the p-1sc-1 is for cars vettes its more aggressive but the truck style is cheaper to make into a d1 with a bigger impeller less machine work is needed to install the d1 impeller $100 to be exact!
Former Vendor
The difference between the P-1SC and the P-1SC-1 is both the impeller and compressor housing. The P-1SC is a straight cut impeller and shares the common street trim 6.25" exducer where the P-1SC-1 is a smaller 5.25" exducer with a helical spun impeller. If you really get into specs you can consider the P-1SC-1 a mini version of the D-1SC impeller. The P-1SC-1 is technically a better supercharger than the P-1SC because of its impeller design. Other than that they are the same. (Bearings, Step-up Ratio, etc)
P-1SC Impeller:
P-1SC-1 Impeller:
P-1SC Impeller:
P-1SC-1 Impeller:
A/C Man is correct that the standard P1-SC is great for trucks and lower rev'ing motors, he is incorrect on the price for upgrade. You can contact Procharger Tech for current pricing on P1 to D1 upgrades.
yea what i ment on the price is it cheaper to make a D1 out of the one with the bigger impeler 100.00 less machine work no need to cut out the housing to fit the D1 impeller! and its about ($1500.00+shipping at procharger) for the P1 to D1 upgrade!but house of boost is a dealer they can save you some money!
Former Vendor
