The sprag pulley is a great idea but I'll let you know right now, don't let ProCharger find out you run one because they won't even touch your blower if it crashes. Even if its still under warranty. Its a part of their repair policy. You're much better off running a standard ProCharger cog pulley and staying off the limiter.
I am not using one, but i have seen other use the pulley and it seemed to work well with there 6 speed cog setup. Sometimes though it still hard to stay off the limiter since these motors spin up so fast. LOL!
Thanks for the reply. I also tried that as well no luck using the email on the site. No phone number either. v11 xb-110 with A&A bracket is the other option I guess!
