T trim or YSI
T trim or YSI
Does anyone know the price for each or the price you paid off the top of your head? Also, will the YSi require an 8 rib pulley upgrade?
Location: Greater Detroit Metro MI, when I'm not travelling.
Vortech lists all their prices online. At full retail a T-Trim costs about $2900 depending on the casing (helical vs straight cut gears, self oiled vs engine fed, satin vs polished involute). and the YSi costs $3400. Dealer cost is lower of course.
http://www.vortechsuperchargers.com/
You will most certainly need an 8-Rib to drive the YSI. Drive power is MUCH higher for those big blowers; it'd be pointless to even try it with a 6-Rib.
St. Jude Donor '10-'11-'12
I'd call A&A on the T-trim vs. Ysi cost question, but the main question you have to ask is how much power are you shooting for? I was comparing the different Vortech blowers on their website and man that Ysi is impressive. I am also considering switching out to a T-trim from my Si-trim, but my next mod will be upgrading the A6 trans. I'm happy with the Si and a 3.4 pulley...until next year. Good luck with your choice.
I'm running a Si Trim V3 right now, but will be sending the car back to the mainland US for an engine build. No offense to the local guys here in Hawaii, but I just don't think they have the raw experience with corvette specific builds and I need to know that this is done right. I want my car to run 100% instead of 99... and that can only be done by corvette specific experts.
Although I'll probably shoot for 750-800 whp, I don't want to limit myself in the future in case I lose the rest of my marbles...
I know the T-Trim maxes out at about 750 or so, and that would limit the build at that point. Having said that, I wanted to just go big and back of the boost with a fully built motor. That way, I'll have a "bullet proof" block with all the power I want, AND the ability to turn it up with a pulley swap... I don't want a 1000 hp beast, I just want to know that I've got options in case I get beat on the street, which has not happened yet.
Thanks for the input fellas, very much appreciated!
St. Jude Donor '09-'10
Go with the Ysi. It is a great head unit. Remember, you can always run a restrictor plate until you are ready to turn up the boost.
I just made 737whp with the T-Trim and 3.4 pulley on straight 101 octane last night, 17 degrees of timing.
Completely factory long block, stock heads/cam, etc.
Stock clutch!
Only fuel mod is a MSD BAP....
Stock clutch!
Heh, ive alwaya been a gambling man. Feel confident my tune is money......to be determined.
Will post a dyno graph tonight when i get home.....
And this was on a mustang dyno loaded......probably 750+ on a Dynojet.
Platinum Supporting Vendor
Personally, I'd do a T Trim with 8 rib. 3.125 pulley and 8" balancer.
That makes a nice daily driver.
It's just a good street combination, in my opinion.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
Yes Sir, the A&A email has been sent, I was just looking for a more immediate reply, as well as some A&A swap/upgrade prices that existing members have gotten.
understand where you coming from.I would do the same when it comes to engine build.
Former Vendor
We custom build dozens of SC Corvettes every year...we also sell & ship about every custom performance part available for the C5's & C6's...
You can make 12-13lbs of boost on a YSI with a 6-rib set up, and the correct belt..!!
Call me and I will be glad to help in anyway I can...
This is the T-Trim with the 3.4 pulley......all factory long block, stock cam, etc....101 octane unleaded gas...
Just the MSD Boost-A-Pump and 60 lb injectors....
The before is the 3.8 pulley with same mods....93 octane.
I give you credit, you've got far more in-******** fortitude than most, I hope your check book matches that set.
