LSX376 INSTALLED - Auto A6 + D1 + 13psi = 750rwhp NO METH
Fuel and Tranny limited.. room to grow.. NO METH!
2008 JSB AUTOMATIC A6 -
GM LSX376 Crate Engine
Heads - Stock LS3 6 Bolt
Engine Type: LSX Series Gen IV small-block V-8 with 68cc chambers
Displacement : 376 (6.2L) Valve Size : 2.16 intake / 1.59 exhaust
Bore x Stroke : 4.06 x 3.62 Compression ratio: 9:1
Block : LSX cast-iron with 6-bolt Rocker Arms
Investment-cast, roll trunnion cross-bolted main caps Rocker Arms
Crankshaft - Nodular iron
Rocker Arm Ratio: 1.7:1
Connecting Rods - Powdered metal
Pistons: Forged aluminum
Camshaft Type: Hydraulic roller Reluctor Wheel: 58X
ADM Performance Fuel System
ADM ported TB and Intake
Cam 215/247 .629/.656 121LSA
Procharger D1 12-13psi
Dallas Performance 10-rib\Flip Drive setup "Thanks Taylor for your help!!"
Stainlessworkx 1 7\8
RPM Built Differential 3.42's
Yank 3200 Stall
Centruy Transmission Built A6
B&B Bullets
other stuff I cannot remember..
743\648 at the wheels
Andy put together for me one seriously kickass ride!! I cannot thank ADM PERFORMANCE ENOUGH!!! As always, they come though with the goods!
http://www.youtube.com/watch?v=SJgHn...st=UL&index=23 had to back off a little bit from here because of fuel limitations
Yank 3200 Stall
B&B Bullets
Congratulations! You should really consider methanol injection at that power level, or just go E85... our setups don't like Tx heat, methanol would allow you to keep her purring for a long time!
[IMG][/IMG]
Where is that pump located? Good find!
I have a Kroger 1 mile from the house that has 2x E85 pumps, but I do have a tune for E100 as well...
behind Motor Sports Ranch race track.. Cresson TX. "south fort worth" about 10miles from my house. I have a few e85's next to me as well. I wish E100 would come out already! E85 conversion is probably my next step.. Any idea when E100 will hit the mainsteam market place?
St. Jude Donor '10-'11-'12
Hey, Bro
I noticed in another thread that you sent the car to Houston for trans work. Is this for fine tuning the trans? I am looking to do the Century upgrade in January with a 3200 or 3600 converter. Love your car..nice power and looks
Hey WIld, I am down here in Crowley. Do you ever track your car in Cresson? I see Lambo's, actually every imported car you can think of on that track all the time. They have to have a vette club out there..
