Racelogic - From the Horse's Mouth
I've never been able to find a reason why no one has fitted a vette with the Racelogic traction system. I've heard rumors that you have to swap out the hubs, ABS is incompatible, etc. I've only found one short youtube video of a blown vette using it across the pond:
http://www.youtube.com/watch%3Fv%3DQzwziIJaAIM&sa=U&ei=6lH-TPaHJdGcnwesxPDOCQ&ved=0CBsQtwIwAw&usg=A FQjCNHY7eaim69urYihx9djC1WN_jYxgA
I wrote them last night to see what the deal was and got this response in short order:
So it looks to me like the RLTC8DIAW is what we'd need. It would require splicing into every injector and each wheel speed sensor (with resistors in line). It is pricey at 850# or ~$1350 and you may as well spend the extra 100# for the full throttle shift.
So there, it's doable. Someone do it already.
Thank you for your enquiry.
The ABS ECU on the Corvette does get slightly upset by the load being put on it when you connect the wheel speed signal wires for the traction system – an ABS warning lamp is illuminated when the car reaches about 75mph. However, it’s easily remedied by fitting 10k resistors in line on the connection.
Other than this there are no compatibility issues and RLTC works well on these cars.
Please let me know if I can help with anything else.
Regards,
Mike Broadbent,
Sales Manager.
Regards,
Mike Broadbent,
Sales Manager.
Best thread about it was here http://forums.corvetteforum.com/c6-f...trol-unit.html
Before it got locked for bringing an old thread to life.
Location: Greater Detroit Metro MI, when I'm not travelling.
I know LG was working on it some time ago, but it never went anywhere. I called them and asked about it and they said they were just busy with other projects but would finish it some time.
Someone else also started a project with it but that too never went anywhere.
My understanding is that the wheel speed sensor signal from the Corvette does NOT work with the Racelogic system and that new hubs would have to be fitted to the car. I've heard this from both LG and from a friend who e-mailed Racelogic.
I'm very interested in the system but don't feel like being the guy who braves new ground trying this out on his DD...
1 Post
In reading RL's response it seams as though there is a input impedance mismatch when working GM ABS. Did read installation guide and values appear correct for VR sensors, maybe they use older type input signal conditioning.
I someone really wanted to use this unit I'm sure some form VR signal isolation is possible. Another potential issue is what kind of input Hz can unit handle as C6 hubs have a high pulses per revolution count.
Mike
Mike
BJK
I don't like it. Boost by gear is not dyanmic enough to work reliably in all conditions. I am in the process of throwing more/better rubber at my problem but even then, an advanced form of traction control like the Racelogic would theoretically put down as much power as whatever tires I have are capable of on whatever surface they are on, at launch, straight line and even in turns. Road temps change, starts raining, change my tires, doesn't matter. Like Sam though, I don't want to drop $1500-$2k and be the guinea pig.
Former Vendor
Are you running meth injection Bill?
Taylor:
I don't think that makes much of a difference... On my car for example, I run dual 10lbs/hr nozzles, at 120PSI with a digital progressive controller; same basic setup most people here run. At my power level (680RWHP) the methanol accounts for 9 - 10% at most of my overall fuel charge. The methanol is coming in at 20 pounds per hour, but there are eight 60lbs/hr fuel injectors there too and they are going at 90% duty cycle...
That means when fuel cut happens, my air/fuel ratio is over 100:1. That is not an igniteable mixture (anything over about 19:1 starts to produce a lean misfire), and even if it could ignite, it wouldn't release enough energy to do anything.
Unless I am missing something here? See below:
If that was true we'd all be blowing up when we hit our rev limiters... I've hit mine many times and I've seen the car hit it on the dyno too with no issues. The only thing you see is that some times it will shoot a fireball from the exhaust if enough methanol accumulates in the pipes.
a friend of mine had this installed on his Z06 since more than two years ago, and it worked WONDERS.
I remember we used to go around a round-about at FULL THROTTLE for like 3 or 4 complete turns LOL and the car would stay on its lane.
You had to tune the traction control unit as well, and choose slip in percentage for straight vs after the wheels turn xx angle before it switches to another value.
like 10% slip straight line, and 0% slip in a circle.
Also its worth mentioning the guy raced his Z06 the entire time on the track and drove it as a DD with the unit.
I might be able to help you out if you are serious about this, problem is this dude doesnt like to help for free
Former Vendor
Taylor:
Sounds like you will be the perfect guinna pig then
You absolutly can blow the motor by bouncing off the rev limiter with methanol. This is different for each combo based on how much methanol you are using.
Do me a favor and hold your car on the limiter for 30 seconds and see how long it lasts
As one of the few people on this board that has actually installed and calibrated a few RaceLogic boxes on other platforms I can tell you that it goes through a series of 5 levels/stages of fuel cuts. You can configure it a million ways and you will be at risk of hurting the engine if you are using methanol.
Until this very second, I've had two choices: Deal with no traction and a lot of HP, or drop another 6k on a custom set of 18/19" rims that can fit a sticky tire.
Though this sounds like an extremely specialty item that not just anyone can get right...
My car is going to Andy's shop here in the next few weeks for some new goodies, and I'd REALLY like to have anything and everything done while it's in California. The local guys can barely get the custom tune right, let alone deal with boost by gear issues...
You can configure it a million ways and you will be at risk of hurting the engine if you are using methanol.[/QUOTE]
Do you feel methanol triggered by idc would not have this problem and it would then be a good traction system?
