C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
125 shot NX jetting?
Old 01-10-2011, 09:35 AM
BT03mach-1
BT03mach-1's Avatar
Default 125 shot NX jetting?
I'm getting my car tuned today and i want to jet it for 125 shot. does anyone know what size jets i should use? i have found 57n and 31-35f. NX website just has 100 shot and 150 shot.
Thanks!
Old 01-10-2011, 01:00 PM
ls3gotcha
ls3gotcha's Avatar
nx 125 = 57/33
Old 01-10-2011, 01:03 PM
BT03mach-1
BT03mach-1's Avatar
Thanks!!! thats what i thought i just wanted to make sure.
Old 01-10-2011, 01:05 PM
ls3gotcha
ls3gotcha's Avatar
come back and update us on what she puts down
Old 01-10-2011, 01:28 PM
BT03mach-1
BT03mach-1's Avatar
i will. I'm going at 2 today. mods are no cats, vararam and b&b bullets and 125 shot.
friday at the track i ran 12.0 @ 123 2.0 60' with a 100 shot and no tune (i know not good) on street tires
Old 01-10-2011, 02:29 PM
Flash20
Flash20's Avatar
spray a 150
Old 01-10-2011, 05:24 PM
TRINIC5
TRINIC5's Avatar
Use two stages, first at 100 and second at 150 and you will enjoy it, after that you will never run the car without it. Don't worry a stock motor can handle that without any issues, I did it with a stock LS1 and my car went 10.60et with no modification to the motor.
Old 01-11-2011, 08:17 AM
BT03mach-1
BT03mach-1's Avatar
Old 01-11-2011, 09:51 AM
Flash20
Flash20's Avatar
good power! congrats
Old 01-11-2011, 09:11 PM
dicky
dicky's Avatar
this is only a 125 shot right? if so nice gains thats alot of tq. when do you plan on running it at the track?
Old 01-12-2011, 07:56 AM
BT03mach-1
BT03mach-1's Avatar
thanks!
yeah just a 125 shot. I'm going back to the track after i get that ecs rearend/trans brace and dr's
Old 01-15-2011, 05:58 PM
jaglmm
jaglmm's Avatar
i'm about to install a 125 shot in my car..
i was hestiant about the stock motor it has 100k miles but after some reading i think my motor should be fine for some time to come
Old 01-15-2011, 06:01 PM
jaglmm
jaglmm's Avatar
is it typical for a vette to run 10's on 150 shot only..
G*DDAMN!!
Old 01-15-2011, 06:16 PM
turbotuner20v
turbotuner20v's Avatar
wow, is that torque reading right?
Looks pretty lean on the hit.
Old 01-17-2011, 08:27 AM
BT03mach-1
BT03mach-1's Avatar
he said its because it sucked the fuel out of the fuel rails and the pump had to catch up. i think he called it a nitrous spike? something like that.
yeah the torque reading is right. i dont know why it wouldn't be
Old 01-17-2011, 10:29 AM
turbotuner20v
Sometimes if the magnet or clip on the rpm signal wire skips a beat the tq reading will get wonky... that's impressive that you're making over 620ft-lbs of torque... it looks like it's occuring through the lean spike though, so that makes sense I guess.
Have you checked your plugs? I'm curious how the motor likes that ~500rpm lean spot w/ such high cylinder pressure. Was your tuner concerned about that behavior, or is that length of a lean spot normal for nitrous?
Old 01-17-2011, 12:08 PM
Flash20
Flash20's Avatar
throw a bigger shot on it, and let it eat. Might wanna check your plugs. btw which plugs are you running?
my stock ls3 lasted forever and never died until i decided to upgrade
Old 01-17-2011, 12:12 PM
BT03mach-1
BT03mach-1's Avatar
tr6 4177 gapped at 33. they look fine I'm going to put in new ones before i go to the track Friday.
Old 01-22-2011, 01:01 PM
dicky
dicky's Avatar
well how did it do?
To 125 shot NX jetting?
Quick Reply: 125 shot NX jetting?
