C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
MSD 2 Step
Old 01-07-2017, 02:09 PM
SinisterC6
SinisterC6's Avatar
Originally Posted by furious465
No I didn't solder but I used connectors and heat shrink, I do have a multi meter.
Perfect! I prefer solder but theres been say that a crimp works better because solder can crack from vibration, no clue if true
Old 01-10-2017, 05:00 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Well crimped stuff can work as good as anything.. problem is people using $7 crimpers from walmart that aren't much better than smashing the connector with a pair of pliers. IMO anyways.
So, I usually crimp and then solder too. It's overkill but whatevs
Old 01-10-2017, 07:54 PM
furious427
furious427's Avatar
I hear what you are saying, I got a pair of real crimpers though, been there done that with the bs ones.
Old 01-11-2017, 07:35 AM
rob20rx7
rob20rx7's Avatar
I hooked up the LNC in my car and haven't quite been able to set it up correctly. anyone been able to get it right on theirs?
Old 01-11-2017, 07:42 AM
furious427
furious427's Avatar
Pretty sure they hook up the same way as the MSD, are you trying to hook up the limiter on it or the timing control?
Quick Reply: MSD 2 Step
